Target Version Prefix - Specify which version Chrome can update to
  • April 5, 2022
  • 117 views
Hello,
I have a configuration profile that ensures that Chrome is always on the latest version using  com.google.keystone
and within it the Google Update Policy is set with a Target Version Prefix.
At the moment I have to go into this policy and update the Target Version Prefix every time Google release a new major version of Chrome (which feels like every couple of weeks at the moment).
Is there a way of setting it so that I don't have to update it every time (maybe leave it blank or set to 1000?)
Thanks
Best answer by sdagley
@AlexSchajer Remove the Target Version Prefix in your configuration profile and Chrome should always update to the latest version available (by adding that setting you're telling Chrome you want to limit updates to that version)
1 reply
sdagley
  • April 5, 2022
