Jamf PRO Intune Integration Error
  • April 5, 2022
  • 16 views
Hi Community,
we are facing a strange issue that out of sudden our Jamf PRO integration with Intune does not work anymore.
We get this error here:
Could not retrieve the access token for Microsoft Graph API. Check the configuration for macOS Intune Integration.
2022-04-05 08:37:15,496 [WARN ] [Thread-3 ] [itionalAccessHTMLResponse] - Could not handle provisioning
org.springframework.web.client.HttpClientErrorException$Forbidden: 403 Forbidden: "{"odata.error":{"code":"Authorization_RequestDenied","message":{"lang":"en","value":"Insufficient privileges to complete the operation."},"requestId":"d123ebf4-3431-46ae-ac79-90bfc10c4052","date":"2022-04-05T06:37:15"}} "
From Azure AD App Registration I have set all required API Permissions.
Any Idea?
BR Tim
1 reply
  • June 27, 2022
Had the same issue today and the documentation has two (new?) permissions to set.
After adding the permissions, everything worked as before.
Manually configure Jamf Pro Integration with Microsoft Intune - Microsoft Intune | Microsoft Docs
