Set computer name User folder and Serial Number
  • April 5, 2022
  • 6 replies
  • 63 views
So the below script was working fine and now no longer wants too. What am i missing?
CurrentUser=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "\\n");')
SerialNumber=$(system_profiler SPHardwareDataType | grep "Serial Number" | awk -F':' '{print $2}' | sed -e 's/^[ \\t]*//' -e 's/[ \\t]*$//')
### Set the computer name using the jamf binary
/usr/local/bin/jamf setComputerName -target / -name "$CurrentUser"-"$SerialNumber"
Best answer by GrahamJ
okay, think i got it working.
userName=$(/bin/ls -la /dev/console | /usr/bin/cut -d " " -f 4)
computerName="$userName-$SerialNumber"
# Set the ComputerName, HostName and LocalHostName
/usr/sbin/scutil --set ComputerName "$computerName"
/usr/sbin/scutil --set HostName "$computerName"
/usr/sbin/scutil --set LocalHostName "$computerName"
DBrowning
  • April 5, 2022
@GrahamJ I'm going to guess you are on macOS 12.3.  python was removed in macOS 12.3.  https://www.macrumors.com/2022/01/28/apple-removing-python-2-in-macos-12-3/
  • April 6, 2022
neat miss on my part
Forum|alt.badge.img+20
  • April 6, 2022
Recommend changing your script to use this command to get the Current User:
currentUser=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
  • April 6, 2022
Still missing something. Still kicking an -name error.
  • April 6, 2022
Forum|alt.badge.img+21
  • April 6, 2022
Just remember that device names are broadcast in the clear on any associated network, so it is generally advisable to avoid PII in the device name if at all possible.  If all of your users are adults, it may not be an issue, but would be a HUGE red flag in K12 due to the privacy and safety concerns.  Just my $0.02.
