Looking to see if anyone else is seeing double Acceptable Use Policy Prompts on M1x devices.
When booting the device, (FV enabled) we see the "legacy" Apple AUP popup, and then again when the Jamf Connect Login window loads, we see the "JCL" AUP screen.
Anyone else seeing this on M1x devices?
Page 1 / 1
And I'm sure someone is going to say just set it in Jamf Connect, but we want/need to be able to catch all devices that may not have JC installed to make sure they are seeing the AUP.
