Running AcroCleanerTool Silently to uninstall Adobe Acrobat Reader DC
  • May 5, 2022
  • 6 replies
  • 329 views
Forum|alt.badge.img+21
I have tried downloading the tool from here AcroCleaner — Acrobat Desktop Tools and Utilities (adobe.com)
There are instructions for Windows but nothing for mac. Does anyone know how to run this silently?
donmontalvo
Forum|alt.badge.img+36
  • May 7, 2022
Years ago we had a gold contract with Adobe. We had no luck removing old suites and Acrobat. On a support call, Jody Rogers (who worked at Adobe at the time) advised we erase/rebuild a computer if we wanted/needed to remove anything Adobe. Best advice ever, 100% successful. :)
  • May 13, 2022
Ive managed to capture the files for Adobe Reader uninstall script. The pain was Adobe Acrobat for Mac. I managed to have success and uploaded it to my github here Scripts/Bash/Uninstall Acrobat at master · tkimpton/Scripts (github.com)
shrisivakumaran
can you share script for Adobe Reader/ Adobe Reader DC/ Adobe Reader Pro uninstall
  • July 24, 2023
I came looking for the Acrobat Pro removal script. Have you tested it on Adobe Acrobat DC?
shrisivakumaran
@kacey3 do you need script to remove Acrobat Pro only or all Adobe Product. I have some scripted test to remove complete Adobe application.
  • January 18, 2024
I'm interested in removing Acrobat Pro and Reader as part of a cleanup project.
