Hi Im trying to set up a restrictions-profile for some BYOD-iPhones. Some restrictions get pushed correctly but the two most important ones won't show up on the iPhone.
Settings are:
Voice dialing while device is locked Restricted Server-side logging of Siri commandsDeprecated Restricted Users to accept untrusted TLS certificates Restricted Trusting new enterprise app authors Restricted Managed apps can write contacts to unmanaged contacts accounts Restricted Unmanaged apps to read contacts from managed contacts accounts Restricted Sending diagnostic reports to Apple Restricted Apple Watch wrist detection Restricted
But these two get ignored:
Testing-iPhone is running iOS 15.4.1
This is what ends up on the iPhone.
do those settings require supervised or DEP?
for informational purposed (we have not gone BYOD yet but I see it on the horizon) do you see these as potential attack vectors or are you just going with trying to match with company owned devices?
Restricted
Restricted
Restricted
The shouldn't as they are advertised special for BYOD.
These three have different reasons:
We see voice-dialing and Apple Watch wrist detection as potential attack vector (like someone using the phone of a higher employe to get informations).
Diagnostic reports is to be compliant with European GDPR.
Seems like these two
need these two
Documents from managed sources open in unmanaged destinations Restricted Documents from unmanaged sources open in managed destinations Restricted
to get applied. But the contacts restrictions won't be displayed under Settings -> Management -> Restrictions.
More in this thread:
https://community.jamf.com/t5/jamf-pro/unmanaged-app-reading-managed-contacts-although-restriction-is/m-p/265589#M243796
thanks for the info
