Monterey 12.4 upgrade "Setup Assistant" has iCloud Drive for Desktop/Documents default checked
  • May 17, 2022
  • 28 views
"All your files in iCloud" is checked by default in Setup Assistant (after upgrading, not reinstalling) to 12.4.
GDPR nightmare TBH.
Configuration profile to disable that? Any other way?
RaxiaDK
  • May 17, 2022
  • May 17, 2022
As you noticed on Slack, I figured it out. It's a bit simpler than that :) Jamf custom profiles don't need all the metadata from Profile Editor.
This will do:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>SkipiCloudStorageSetup</key> <true/> </dict> </plist>
RaxiaDK
  • May 17, 2022
This will do:
Hehe hey :D
Yes. Jamf pro wrap it in a MCX payload.
I am not that lucky with other MDM
