Office 2021 Your Privacy Matters POPUP -- how to stop it
  • May 23, 2022
  • 106 views
Forum|alt.badge.img+20
Hi, I use a script to stop the Office 2016/2019/2021 first run popups but the only popup that still appears is the 'YOUR PRIVACY MATTERS'.  What would i need to add to the script to not have this popup appear?
# Office 2016/2019/2021 for Mac presents "first run" dialogs to the user to market some of its new features.
# This script will suppress these "first run" dialogs using the following settings:
# Setting: kSubUIAppCompletedFirstRunSetup1507 – boolean value (true / false)
# Function: Suppresses the "What’s New" dialog for Office 2016 applications' first launch
# Setting: FirstRunExperienceCompletedO15 – boolean value (true / false)
# Function: Suppresses additional "What’s New" dialog for Outlook and OneNote.
# Note: That is a capital letter O in "O15", not zero15.
# Setting: SendAllTelemetryEnabled – boolean value (true / false)
# Function: Suppresses the offer to send crash reports to Microsoft
# Source for settings:
# http://macops.ca/disabling-first-run-dialogs-in-office-2016-for-mac/
# Set whether you want to send diagnostic info back to Microsoft. If you want to
# offer the choice of sending diagonostic data back to Microsoft, set the following
# value for the submit_diagnostic_data_to_microsoft variable:
# submit_diagnostic_data_to_microsoft=true
# By default, the values in this script are set to send no diagnostic data to Microsoft:
submit_diagnostic_data_to_microsoft=false
DisableOffice2016FirstRun(){
# This function will disable the first run dialog windows for all Office 2016 apps.
# It will also set the desired diagnostic info settings for Office application.
/usr/bin/defaults write /Library/Preferences/com.microsoft."$app" kSubUIAppCompletedFirstRunSetup1507 -bool true
/usr/bin/defaults write /Library/Preferences/com.microsoft."$app" SendAllTelemetryEnabled -bool "$submit_diagnostic_data_to_microsoft"
# Outlook and OneNote require one additional first run setting to be disabled
if [[ $app == "Outlook" ]] || [[ $app == "onenote.mac" ]]; then
/usr/bin/defaults write /Library/Preferences/com.microsoft."$app" FirstRunExperienceCompletedO15 -bool true
# Run the DisableOffice2016FirstRun function for each detected Office 2016
# application to disable the first run dialogs for that Office 2016 application.
if [[ -e "/Applications/Microsoft Excel.app" ]]; then
app=Excel
if [[ -e "/Applications/Microsoft OneNote.app" ]]; then
app=onenote.mac
if [[ -e "/Applications/Microsoft Outlook.app" ]]; then
app=Outlook
if [[ -e "/Applications/Microsoft PowerPoint.app" ]]; then
app=Powerpoint
if [[ -e "/Applications/Microsoft Word.app" ]]; then
app=Word
exit $?
  • August 12, 2022
Don't know if you found a solution for this, but I solved this by adding "HasUserSeenEnterpriseFREDialog" with a boolean value of false to my config profile for the com.microsoft.office pref.
  • August 15, 2022
@mrudlin  can you show me a screenshot of your config profile with this "HasUserSeenEnterpriseFREDialog"
or could i just simply add that to the script? (see below)
/usr/bin/defaults write /Library/Preferences/com.microsoft."$app" HasUserSeenEnterpriseFREDialog -bool true
nanderson
  • October 14, 2022
It looks like it cannot be suppressed depending on the situation:
