Did something change with either an update in Jamf Pro Cloud or with macOS 12.x regarding the 'Waiting Room' folder?
Have a script that worked great until recently.
sudo echo "---OUR SITE CODE---" > /Library/Application\\ Support/JAMF/Waiting\\ Room/com.sentinelone.registration-token
sudo /usr/sbin/installer -pkg /Library/Application\\ Support/JAMF/Waiting\\ Room/SentinelAgent_macos_v21_7_4_5853.pkg -target /I am getting this when that script runs from a policy
Script result: /Library/Application Support/JAMF/tmp/Install SentinelOne: line 1: /Library/Application Support/JAMF/Waiting Room/com.sentinelone.registration-token: No such file or directory
installer: Error - the package path specified was invalid: '/Library/Application Support/JAMF/Waiting Room/SentinelAgent_macos_v21_7_4_5853.pkg'.
Error running script: return code was 1.In looking on the machine, there is no /Library/Application Support/JAMF/Waiting Room/ folder. Did that functionality move somewhere else? Or is there a better way to push that down? Not seeing any new documentation on the SentinelOne knowledge bases.
