jamfMessenger v3.x
  • May 25, 2022
  • 6 replies
  • 96 views
UPDATE: I have added this script to my gitHub repo. You can find the freshest of the fresh here...
Hey everyone! It's been awhile since I've contributed anything to Jamf Nation.
I have a script / workflow that I've been sitting on since 2019 that I am finally ready to share...
I'm certain many of you use jamfHelper and for the most part, the jamfHelperGUI app is all but a dinosaur sitting on a couple of forked gitHubs out on the interwebs.
That being said, I got tired of writing jamfHelper pop-up windows for every workflow that needed one. I wanted something a bit more cookie-cutter... something I could drop into my Jamf Pro Scripts repository and call from within a policy by leveraging Jamf Pro's Scripts "Options" features.
So I set out to write a one-size fits all script to assist with the daily grind of pop-up communications.
So without further ado, I give you my latest iteration of jamfMessenger... version 3.x... oooh! shiny!
#!/bin/sh ############################################################################## # # FILENAME: jamfMessenger.sh # ############################################################################## # # DESCRIPTION # Jamf Messenger is a script that allows a Jamf Admin to send pop-up messages # to end users/devices by leveraging the jamfHelper GUI application. # ############################################################################## # # CHANGE CONTROL # v3.1 - 2022-05-25 # Updated by Caine Hörr # Added a simplistic debug mode (more to come?) # Added examples for use with Jamf Script Options # Identified need for {} with values above 9 for Jamf Script Options # Added "Known Issues" section # # v3.0 - 2022-05-24 # Updated by Caine Hörr # Added ability to use UNICODE characters within pop-up windows # Added ability to use URL for pop-up icon image # Added countdownPrompt message # Added Message_Body_Line_4 message # Resolved issue with -lockHUD not being recognized # Resolved issue with -countdown not being recognized # Resolved issue with -fullScreenIcon not being recognized # # v2.0 - 2021-08-10 # Updated by Caine Hörr # Changed shebang from "bash" to "sh" to support zsh # Added additional lines for message body to support line breaks # Expanded code to utilize all features of jamfHelper # # v1.0 - 2019-08-20 # Written by Caine Hörr # Original script creation (jamf_Messenger.sh) # ############################################################################## # # KNOWN ISSUES # # UNICODE characters don't pass from Jamf Script Options to the final output # Currently requires hardcoding. <insert sad face here>. # I won't give up trying to make this happen! # # Jamf Script Options are limited from ${4} through ${11}. You can't pass # ALL THE THINGS this way. I have a few ideas about how to get around # this limitation. Version 4.x perhaps? # ############################################################################## # Enable/Disable Debug Mode # Enabled provides verbose logging output to Jamf # Comment to disable debugMode="true" ############################################################################## # # Unicode Characters for added impact # # For additional symbols: https://unicode-table.com/en/ # ############################################################################## green_square_white_check_mark_UTF8=$(echo '\\xE2\\x9C\\x85') # UTF-8 (HEX) green_square_white_check_mark_UTF32BE=$(echo '\\U00002705') # UTF-32BE (HEX) red_cross_mark_UTF8=$(echo '\\xE2\\x9D\\x8C') # UTF-8 (HEX) red_cross_mark_UTF32BE=$(echo '\\U0000274C') # UTF-32BE (HEX) large_orange_diamond_UTF8=$(echo '\\xF0\\x9F\\x94\\xB6') # UTF-8 (HEX) large_orange_diamond_UTF32BE=$(echo '\\U0001F536') # UTF-32BE (HEX) large_green_circle_UTF8=$(echo '\\xF0\\x9F\\x9F\\xA2') # UTF-8 (HEX) large_green_circle_UTF32BE=$(echo '\\U0001F7E2') # UTF-32BE (HEX) large_yellow_circle_UTF8=$(echo '\\xF0\\x9F\\x9F\\xA1') # UTF-8 (HEX) large_yellow_circle_UTF32BE=$(echo '\\U0001F7E1') # UTF-32BE (HEX) large_red_circle_UTF8=$(echo '\\xF0\\x9F\\x94\\xB4') # UTF-8 (HEX) large_red_circle_UTF32BE=$(echo '\\U0001F534') # UTF-32BE (HEX) ############################################################################## # # The jamfHelper man page can be found here... # # /Library/Application\\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -help # # Want more examples... # https://apple.lib.utah.edu/jamfhelper/ # ############################################################################## ############################################################################## # # USER CONFIGURABLE SECTION - PART 1 # jamfHelper Pop-Up Window Look & Feel # This section configures all the various elements of the # jamfHelper pop-up window # ############################################################################## # # NOTICE # If using this script with Jamf Pro Script Options: # * Do not use $1, $2, and $3 as they are reserved. # * You may use ${4} through ${11} # * {} Are required for values 10 and 11 - Some Jamf bug # * https://community.jamf.com/t5/jamf-pro/problem-assigning-parameter-10-11-in-script/m-p/128772 # ############################################################################## windowType="hud" # [ hud | utility | fs ] # hud: creates an Apple "Heads Up Display" style window - Header will be BOLD in HUD mode # utility: creates an Apple "Utility" style window - All text is plain # WARNING: utility mode seems to be limited to the amount of text you can display # fs: creates a full screen window that restricts all user input # WARNING: Remote access or multiple monitors must be used to unlock machines in this mode - USE AT YOUR OWN RISK lockHUD="true" #[ true | false ] # true = Remove the ability to exit the HUD window type by selecting the "x" button # false = Allow the ability to exit the HUD window type by selecting the "x" button # If no value is provided, the behavior defaults to "false" windowPosition="" # [ ur | ul | lr | ll ] # Positions window in the upper right, upper left, lower right, or lower left of the user's screen # If no value is provided, the window defaults to the center of the screen title="jamfMessenger v3.0" # Sets the window's title to the specified string heading="You got to get your mind right" # heading=${4} # <-- Uncomment to use with Jamf Script Options. Comment line above. # Sets the heading of the window to the specified string alignHeading="left" # [ right | left | center | justified | natural ] # Aligns the heading to the specified alignment # If no value is provided, the position defaults to "left" Message_Body_Line_1="Because... This is the way..." # Message_Body_Line_1=${5} # <-- Uncomment to use with Jamf Script Options. Comment line above. Message_Body_Line_2=" ${large_green_circle_UTF8} No sleep till Brooklyn" # Message_Body_Line_2=${6} # <-- Uncomment to use with Jamf Script Options. Comment line above. Message_Body_Line_3=" ${large_yellow_circle_UTF8} Walk 500 miles and roll 500 more" # Message_Body_Line_3=${7} # <-- Uncomment to use with Jamf Script Options. Comment line above. Message_Body_Line_4=" ${large_red_circle_UTF8} Nuke 'em from orbit" # Message_Body_Line_4=${8} # <-- Uncomment to use with Jamf Script Options. Comment line above. alignDescription="" # [ right | left | center | justified | natural ] # Aligns the description to the specified alignment # If no value is provided, the position defaults to "left" # The left and natural values appear to behave the same. YMMV! # icon="/path/to/some/icon.png" icon="https://upload.wikimedia.org/wikipedia/commons/thumb/2/24/Warning_icon.svg/1153px-Warning_icon.svg.png" # icon=${9} # <-- Uncomment to use with Jamf Script Options. Comment line above. # Sets the pop-up window's image file to the image located at the specified path # Image Types Supported: ICNS, PNG, JPG/JPEG, TIFF, PDF, and GIF (GIFs will not animate) # Setting to a URL only supports PNG, JPG, and GIF formats tempDirectory="/tmp" # Set the tempDirectory when using an image url iconSize="128" # Changes the image frame to the specified pixel size # Pixel sizes are in integers # If no value is provided, the image will be shown with it's default height and width values fullScreenIcon="" #[ true | false ] # Scales the "icon" to the full size of the window # Note: Only available in full screen mode # If no value is provided, the image will be shown with it's default height and width values button1="Die" # button1=${10} # <-- Uncomment to use with Jamf Script Options. Comment line above. # Creates a button with the specified label # Button 1 is positioned to the right button2="Ride" # button2=${11} # <-- Uncomment to use with Jamf Script Options. Comment line above. # Button 2 is positioned to the left defaultButton="2" #[ 1 | 2 ] # Sets the default button of the window to the specified button. The Default Button will respond to "return" # If no value is provided, no default will be set cancelButton="1" #[ 1 | 2 ] # Sets the cancel button of the window to the specified button. The Cancel Button will respond to "escape" # If no value is provided, the default value is 2 unless lockHUD="true" showDelayOptions="0, 13, 46800, 7862400" # Enables the "Delay Options Mode" # The window will display a dropdown with the integer values passed through the string # Integers must be comma separated (i.e. int, int, int,...) # Common Values: 0 sec = "Start Now" | 60 sec = 1 min | 300 sec = 5 min | 600 sec = 10 min | 900 sec = 15 min | 1800 sec = 30 min | 2700 sec = 45 min | 3600 sec = 1 hr timeout="151200" # Causes the window to timeout after the specified amount of seconds in integers # Note: The timeout will cause the default button, button 1 or button 2 to be selected (in that order) # Common Values: 60 sec = 1 min | 300 sec = 5 min | 600 sec = 10 min | 900 sec = 15 min | 1800 sec = 30 min | 2700 sec = 45 min | 3600 sec = 1 hr # If no value is provided, no timeout value will be provided countdown="true" #[ true | false ] # Displays a string notifying the user when the window will time out # If no value is provided, value will be false # NOTE: "countdown" can only be used in conjunction with "timeout". countdownPrompt="Countdown to Adventure:" # Displays a custom countdown message # If left blank, displays default message alignCountdown="left" # [right | left | center | justified | natural] # Aligns the countdown to the specified alignment # If no value is provided, the position defaults to "left" ############################################################################## # # THERE ARE NO USER SERVICABLE PARTS IN THE FOLLOWING SECTION # SCROLL TO THE BOTTOM SECTION ENTITLED "USER CONFIGURABLE SECTION - PART 2" # ############################################################################## main(){ run_as_root function_debug_mode function_validate_icon function_jamfHelper_Binary function_jamfHelper_Message function_User_Interaction } run_as_root(){ # Check for admin/root permissions # This is used for local testing in case you need to call sudo for any if [ "$(/usr/bin/id -u)" != "0" ]; then echo "" echo "[ERROR]: Script must be run as root or with sudo." echo "" exit 1 fi } function_debug_mode(){ if [[ "${debugMode}" == "true" ]]; then echo "DEBUG MODE ENABLED" fi } function_validate_icon(){ if [[ "${icon}" == *"http://"* ]]; then echo "[ERROR]: Icon settings attempting to use a non-SSL (Port 80) Web URL." echo "${icon}" exit 1 elif [[ "${icon}" == *"https://"* ]]; then echo "Icon settings attempting to use an SSL (Port 443) Web URL." echo "${icon}" if [[ "${icon}" == *".png"* ]] || [[ "${icon}" == *".PNG"* ]]; then fileFormat="png" elif [[ "${icon}" == *".jpg"* ]] || [[ "${icon}" == *".JPG"* ]] || [[ "${icon}" == *".jpeg"* ]] || [[ "${icon}" == *".JPEG"* ]]; then fileFormat="jpg" elif [[ "${icon}" == *".gif"* ]] || [[ "${icon}" == *".GIF"* ]]; then fileFormat="gif" else echo "[ERROR] Format not currently supported." exit 1 fi /usr/bin/curl ${icon} -o ${tempDirectory}/jamfMessengerPopupIcon.${fileFormat} icon="${tempDirectory}/jamfMessengerPopupIcon.${fileFormat}" else echo "Icon uses local file path" echo "${icon}" fi } function_jamfHelper_Binary(){ # Set the path to the jamfHelper binary PATH=$PATH:/Library/Application\\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS } function_jamfHelper_Message(){ # Compose final description (message body text) whiteSpace=" " description="${Message_Body_Line_1} ${whiteSpace} ${Message_Body_Line_2} ${Message_Body_Line_3} ${Message_Body_Line_4} ${whiteSpace}" # Set the lockHUD value accordingly if [[ "${lockHUD}" == "true" ]]; then lockHUD="-lockHUD" else lockHUD="" fi # Set the countdown value accordingly if [[ "${countdown}" == "true" ]]; then countdown="-countdown" else countdown="" fi # Set the fullScreenIcon value accordingly if [[ "${fullScreenIcon}" == "true" ]]; then fullScreenIcon="-fullScreenIcon" else fullScreenIcon="" fi # Determine if the dropdown should be used or not if [[ -z "${showDelayOptions}" ]]; then function_jamfHelper_without_Dropdown else function_jamfHelper_with_Dropdown fi } function_jamfHelper_with_Dropdown(){ userSelection=$(jamfHelper \\ -windowType ${windowType} \\ ${lockHUD} \\ -windowPosition ${windowPosition} \\ -title "${title}" \\ -heading "${heading}" \\ -alignHeading ${alignHeading} \\ -description "${description}" \\ -alignDescription ${alignDescription} \\ -icon "${icon}" \\ -iconSize ${iconSize} \\ -fullScreenIcon \\ -button1 "${button1}" \\ -button2 "${button2}" \\ -defaultButton ${defaultButton} \\ -cancelButton ${cancelButton} \\ -showDelayOptions "${showDelayOptions}" \\ -timeout ${timeout} \\ ${countdown} \\ -countdownPrompt "${countdownPrompt} " \\ -alignCountdown ${alignCountdown}) if [[ "${debugMode}" == "true" ]]; then echo "jamfHelper Syntax:" echo "jamfHelper -windowType ${windowType} ${lockHUD} -windowPosition ${windowPosition} -title "${title}" -heading "${heading}" -alignHeading ${alignHeading} -description "${description}" -alignDescription ${alignDescription} -icon "${icon}" -iconSize ${iconSize} -fullScreenIcon -button1 "${button1}" -button2 "${button2}" -defaultButton ${defaultButton} -cancelButton ${cancelButton} -showDelayOptions "${showDelayOptions}" -timeout ${timeout} ${countdown} -countdownPrompt "${countdownPrompt} " -alignCountdown ${alignCountdown})" echo fi } function_jamfHelper_without_Dropdown(){ userSelection=$(jamfHelper \\ -windowType ${windowType} \\ ${lockHUD} \\ -windowPosition ${windowPosition} \\ -title "${title}" \\ -heading "${heading}" \\ -alignHeading ${alignHeading} \\ -description "${description}" \\ -alignDescription ${alignDescription} \\ -icon "${icon}" \\ -iconSize ${iconSize} \\ -fullScreenIcon \\ -button1 "${button1}" \\ -button2 "${button2}" \\ -defaultButton ${defaultButton} \\ -cancelButton ${cancelButton} \\ -timeout ${timeout} \\ ${countdown} \\ -countdownPrompt "${countdownPrompt} " \\ -alignCountdown ${alignCountdown}) if [[ "${debugMode}" == "true" ]]; then echo "jamfHelper Syntax:" echo "jamfHelper -windowType ${windowType} ${lockHUD} -windowPosition ${windowPosition} -title "${title}" -heading "${heading}" -alignHeading ${alignHeading} -description "${description}" -alignDescription ${alignDescription} -icon "${icon}" -iconSize ${iconSize} -fullScreenIcon -button1 "${button1}" -button2 "${button2}" -defaultButton ${defaultButton} -cancelButton ${cancelButton} -timeout ${timeout} ${countdown} -countdownPrompt "${countdownPrompt} " -alignCountdown ${alignCountdown})" echo fi } ############################################################################## # # USER CONFIGURABLE SECTION - PART 2 # # jamfHelper will print the following return values to stdout # 0 - Button 1 was clicked # 1 - The Jamf Helper was unable to launch # 2 - Button 2 was clicked # 9 - ESC Button was pressed # XX1 - Button 1 was clicked with a value of XX seconds selected in the drop-down # XX2 - Button 2 was clicked with a value of XX seconds selected in the drop-down # 239 - The exit button was clicked # 243 - The window timed-out with no buttons on the screen # 250 - Bad "-windowType" # 255 - No "-windowType" # # WRITE YOUR SCRIPT BELOW THIS LINE # ############################################################################## function_User_Interaction(){ # Identify which button was clicked... user_input_return_value="${userSelection:$i-1}" echo "jamfHelper User Input Return Value = ${user_input_return_value}" # If using showDelayOptions, aquire the time chosen... timeChosen="${userSelection%?}" if [[ -z "${timeChosen}" ]]; then echo "Delay Time Chosen: 0 seconds" else echo "Delay Time Chosen: ${timeChosen} seconds" fi # Identify which button was clicked if [[ "${user_input_return_value}" == "0" ]]; then echo "Button 1 was clicked" # Do something here... elif [[ "${user_input_return_value}" == "1" ]]; then echo "Button 1 was clicked" # Do something here... elif [[ "${user_input_return_value}" == "2" ]]; then echo "Button 2 was clicked" # Do something here... elif [[ "${user_input_return_value}" == "9" ]]; then echo "The Close Button was clicked" # Do something here... fi } main exit
As you can see, it's quite lengthy...
There's a lot of meat in this one.
Here's a screen capture of one of the pop-ups generated using some of the cool features contained therein...
Feel free to use it, hack it, whatever...
I just hope you find it useful...
Questions? Ask em if ya got em! I'll do my best to answer!
Until then... be well Jamf friends!
Best answer by cainehorr
@cainehorr, how can I tie this script to open up the below terminal command when someone press button 2?
/bin/launchctl asuser "$currUserUID" sudo -iu "$currUser" open /System/Library/PreferencePanes/SoftwareUpdate.prefPane
SOLUTION
function_User_Interaction(){ # Identify which button was clicked... user_input_return_value="${userSelection:$i-1}" echo "jamfHelper User Input Return Value = ${user_input_return_value}" # If using showDelayOptions, aquire the time chosen... timeChosen="${userSelection%?}" if [[ -z "${timeChosen}" ]]; then echo "Delay Time Chosen: 0 seconds" else echo "Delay Time Chosen: ${timeChosen} seconds" fi # Identify which button was clicked if [[ "${user_input_return_value}" == "0" ]]; then echo "Button 1 was clicked" # Do something here... elif [[ "${user_input_return_value}" == "1" ]]; then echo "Button 1 was clicked" # Do something here... elif [[ "${user_input_return_value}" == "2" ]]; then echo "Button 2 was clicked" # Do something here... /usr/bin/open /System/Library/PreferencePanes/SoftwareUpdate.prefPane elif [[ "${user_input_return_value}" == "9" ]]; then echo "The Close Button was clicked" # Do something here... fi }
  • May 25, 2022
This is fantastic! Do you have a repo for this for community maintenance and also for ease of implementation?
  • May 25, 2022
I do have a personal gitHub account... I'm afraid I probably don't use it correctly though. Haven't take the proper time to learn gitHub. I probably should though!
  • May 25, 2022
So I went ahead and uploaded it to my gitHub repo...
You can find it here: https://github.com/cainehorr/jamfMessenger
  • July 3, 2023
  • July 5, 2023
Glad I was able to assist you with this on macAdmins Slack.
  • July 5, 2023
SOLUTION
