Force OneDrive Manage Backups
  • June 7, 2022
  • 15 replies
  • 171 views
mykool
Has anyone been able to force the new manage backups in OneDrive? I can't for the life of me get it to work, using both PLIST and JSON. I can get it to force other settings but not the backups. Here is my configuration. Tenant ID has been removed for obvious reasons.
<plist version="1.0">
  <dict>
    <key>DisableTutorial</key>
    <true/>
    <key>DefaultFolderLocation</key>
    <array>
      <dict>
        <key>TenantID</key>
        <string>Tentant ID Here</string>
        <key>DefaultFolderPath</key>
        <string>~/</string>
      </dict>
    </array>
    <key>HideDockIcon</key>
    <true/>
    <key>OpenAtLogin</key>
    <true/>
    <key>EnableAddAccounts</key>
    <true/>
    <key>FilesOnDemandEnabled</key>
    <false/>
    <key>KFMSilentOptIn</key>
    <key>KFMSilentOptInDesktop</key>
    <true/>
    <key>KFMSilentOptInDocuments</key>
    <true/>
    <key>KFMBlockOptOut</key>
    <true/>
  </dict>
</plist>
sdagley
  • June 7, 2022
@mykool That functionality isn't in production yet, and is currently only available when OneDrive Insider Preview is enabled
mykool
  • June 7, 2022
I'm on the insider preview.
sdagley
  • June 7, 2022
@mykool If you select the Backup tab what does it display? If it shows a banner "Your IT Department Wants You to Back Up Your Important Folders" then you've got KFM activated. If not, support for native KFM may not have rolled out to your tenant yet (but that seems odd since it's been rolling out for a while now)
mykool
  • June 7, 2022
Yes, I can get that to work but I want to silently force it, where they can't opt out and it just selects it. Maybe it's just buggy with it being in preview still. I'm going to try on another device and see if I get the same results.
  • June 8, 2022
Hello everyone,
Can you please confirm that the Backup tab will appear only after enabling the OneDrive Insider Preview option?
After I manually put a tick mark I get the Backup tab and Desktop/Documents sync works just fine.
I'm curious is it possible to get the Backup tab function available without going first to the OneDrive Insider Preview?
Thank you in advance.
dmccluskey
  • June 8, 2022
you need Preview enabled to use KFM
this is the plist to enable it
com.microsoft.OneDriveUpdater
<key>EnableFasterRingUpdate</key> <true/> </dict> </plist>
mykool
  • June 9, 2022
As I stated above, I am on the Preview, but thanks.
mykool
  • June 13, 2022
I managed to get it to work on an Intel device, however, I have an M1 with the same OS, config profiles, same OneDrive version, both on insider preview and the M1 won't force the backups. Very weird.
@mykool do you mind sharing the xml/plist file? I'm struggling to get this working for my environment.
Want to enable KFM for intel + ARM but cannot get the Back-up section available.
  • October 13, 2022
It looks like the functionality has made it to production. But I cannot figure out how to enable invisibly for our users. I have created a PPPC to enable full disk access, but the activation of the Backup function in OneDrive does not seem to work.
Is there a .plist or script out there somewhere that solves this issue for us?
Since I am new to editing plist files this way, where would I find my Tenant ID and String (as in the @mykool example above)
I found that the new plist file with:
<key>KFMSilentOptIn</key> <string> ----tenant id--- </string> <key>KFMSilentOptInWithNotification</key> <true/>
 would not work until I had run a script to remove the current OneDrive .plist along with the cached ones and then initiated a restart.
rm -Rf /Users/*/Library/Preferences/com.microsoft.OneDrive.plist rm -Rf /Users/*/Library/Caches/com.microsoft.OneDrive rm -Rf /Users/*/Library/Caches/OneDrive rm -Rf /Users/*/Library/Caches/com.microsoft.OneDriveStandaloneUpdater
For me this is still in testing mode as I first need to make sure all devices are using the latest version of OneDrive.
I plan to push a script to quit OneDrive then remove the relevant files, then install the latest OneDrive using installomator and then finally restart the device.
I have successfully done this on a couple of test devices using the script as a self service item and it has worked for silently enabling backup.
  • November 15, 2022
I just figured this out for my org. I used the example in the initial post and added/changed some choices from Microsoft's article: https://learn.microsoft.com/en-us/sharepoint/deploy-and-configure-on-macos
the key here is after applying the profile, the user also needs a config for onedrive to have full disk access. easiest way is PPPC utility. Once the PPPC config and the onedrive forced sync config are pushed to the user, they need to either restart their Mac or sign out and sign back in to onedrive for the plist to kick in.
  • December 28, 2022
is this in production already? or just on the inside preview?
  • December 28, 2022
It's in production.
  • April 3, 2024
Can anyone share a Config Profile that will uncheck the "Get OneDrive Insider Preview updates" if the end user has it checked?  I eventually want to grey out the option but we currently have users that have the box checked.  It is messing with the Patch Management of OneDrive.
