how do create multiple brew package in single script
  • July 8, 2022
  • 34 views
Paulraj
When we run brew install --cask i am getting this error
sudo: unknown user: brew
sudo: error initializing audit plugin sudoers_audit
Error: Running Homebrew as root is extremely dangerous and no longer supported.
As Homebrew does not drop privileges on installation you would be giving all
build scripts full access to your system.
1 reply
Hugonaut
Forum|alt.badge.img+15
  • July 8, 2022
I think this does what you need it to do, I'd advise changin some of the variable to utilize something other than python commands to obtain user, etc but yeah, I think this is what you're looking for.
#!/bin/bash # Script to install Homebrew on a Mac. # Author: richard at richard - purves dot com # Version: 1.0 - 21st May 2017 # Set up variables and functions here consoleuser="$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + " ");')" brandid="com.application.id" tn="/path/to/terminal-notifier.app/Contents/MacOS/terminal-notifier" cd="/path/to/cocoaDialog.app/Contents/MacOS/cocoaDialog" # Logging stuff starts here LOGFOLDER="/private/var/log/" LOG=$LOGFOLDER"Homebrew.log" if [ ! -d "$LOGFOLDER" ]; then mkdir $LOGFOLDER fi function logme() { # Check to see if function has been called correctly if [ -z "$1" ] then echo $( date )" - logme function call error: no text passed to function! Please recheck code!" echo $( date )" - logme function call error: no text passed to function! Please recheck code!" >> $LOG exit 1 fi # Log the passed details echo -e $( date )" - $1" >> $LOG echo -e $( date )" - $1" } function notify() { su -l "$consoleuser" -c " "'"'$tn'"'" -sender "'"'$brandid'"'" -title "'"'$title'"'" -message "'"'$1'"'" " logme "$1" } # Check and start logging - done twice for local log and for JAMF logme "Homebrew Installation" # Let's start here by caffinating the mac so it stays awake or bad things happen. caffeinate -d -i -m -u & caffeinatepid=$! logme "Caffinating the mac under process id: $caffeinatepid" # Have the xcode command line tools been installed? notify "Checking for Xcode Command Line Tools installation" check=$( pkgutil --pkgs | grep com.apple.pkg.CLTools_Executables | wc -l | awk '{ print $1 }' ) if [[ "$check" != 1 ]]; then notify "Installing Xcode Command Tools" # This temporary file prompts the 'softwareupdate' utility to list the Command Line Tools touch /tmp/.com.apple.dt.CommandLineTools.installondemand.in-progress clt=$(softwareupdate -l | grep -B 1 -E "Command Line (Developer|Tools)" | awk -F"*" '/^ +\\*/ {print $2}' | sed 's/^ *//' | tail -n1) softwareupdate -i "$clt" rm -f /tmp/.com.apple.dt.CommandLineTools.installondemand.in-progress /usr/bin/xcode-select --switch /Library/Developer/CommandLineTools fi # Is homebrew already installed? which -s brew if [[ $? = 1 ]]; then # Install Homebrew. This doesn't like being run as root so we must do this manually. notify "Installing Homebrew" # Curl down the latest tarball and install to /usr/local curl -L https://github.com/Homebrew/brew/tarball/master | tar xz --strip 1 -C /usr/local # Manually make all the appropriate directories and set permissions mkdir -p /usr/local/Cellar /usr/local/Homebrew /usr/local/Frameworks /usr/local/bin /usr/local/etc /usr/local/include /usr/local/lib /usr/local/opt /usr/local/sbin /usr/local/share /usr/local/share/zsh /usr/local/share/zsh/site-functions /usr/local/var chown -R $consoleuser /usr/local chmod g+rwx /usr/local/Cellar /usr/local/Homebrew /usr/local/Frameworks /usr/local/bin /usr/local/etc /usr/local/include /usr/local/lib /usr/local/opt /usr/local/sbin /usr/local/share /usr/local/share/zsh /usr/local/share/zsh/site-functions /usr/local/var chmod 755 /usr/local/share/zsh /usr/local/share/zsh/site-functions chgrp admin /usr/local/Cellar /usr/local/Homebrew /usr/local/Frameworks /usr/local/bin /usr/local/etc /usr/local/include /usr/local/lib /usr/local/opt /usr/local/sbin /usr/local/share /usr/local/share/zsh /usr/local/share/zsh/site-functions /usr/local/var # Create a system wide cache folder mkdir -p /Library/Caches/Homebrew chmod g+rwx /Library/Caches/Homebrew chown $consoleuser:wheel /Library/Caches/Homebrew # Install the MD5 checker or the recipes will fail su -l "$consoleuser" -c "/usr/local/bin/brew install md5sha1sum" su -l "$consoleuser" -c "echo "'"export PATH=/usr/local/opt/openssl/bin:$PATH"'" >> ~/.bash_profile" # Remove temporary folder rm -rf /usr/local/Homebrew else # Run an update and quit notify "Updating Homebrew" su -l "$consoleuser" -c "/usr/local/bin/brew update" 2>&1 | tee -a ${LOG} exit 0 fi # Make sure everything is up to date notify "Updating Homebrew" su -l "$consoleuser" -c "/usr/local/bin/brew update" 2>&1 | tee -a ${LOG} # Notify user that all is completed notify "Installation complete" # No more caffeine please. I've a headache. kill "$caffeinatepid" exit 0
