Extension Attributes Kerberos
  • July 26, 2022
  • 8 replies
  • 85 views
dmccluskey
I could use a little help
I am trying to make EA to report back when a user has signed into Kerberos SSO.
The way I am trying to go about is the read the SSO log file and scan for the word "Principal"
If Principal is in the log then the user signed in.
This is the EA I tried to make that is not working.
Thanks for any help
loggedInUser=$( /usr/bin/who | /usr/bin/awk '/console/{ print $1 }' )
KSSOUSERID="$( /Users/$loggedInUser/Library/Logs/Kerberos_SSO.log | grep Principal | cut -d '=' -f2 | xargs)"
if [[ "${KSSOUSERID}" == "" ]] ;
then
/bin/echo "<result>Not Signed-In</result>"
/bin/echo "<result>Sign-In Complete</result>"
Best answer by dmccluskey
that did it
thanks guys
KSSOUSER=$(defaults read //Users/$loggedInUser/Library/Group\\ Containers/group.com.apple.KerberosExtension/Library/Preferences/group.com.apple.KerberosExtension.plist acme.ORG:userName)
if [[ "${KSSOUSER}" == "" ]]
then
/bin/echo "<result>None</result>"
/bin/echo "<result>${KSSOUSER}</result>"
sdagley
  • July 26, 2022
@dmccluskey Are you sure the log file is present if you don't have debug logging enabled? My org uses Kerberos SSO and even though I'm signed in I have no log file in the path you're using.
dmccluskey
  • July 26, 2022
we do, our KSSO was built with help from apple and it creates a log file.
dmccluskey
  • July 26, 2022
Maybe it would help instead of focusing on the log file present or not....
how does one make a EA to scan a file and report back if a word is present. and if that word is present that makes the answer for the result.
damienbarrett
Forum|alt.badge.img+19
  • July 26, 2022
We use Apple's Kerberos/SSO plug-in also. I also have this Kerberos_SSO.log file in ~/Library/Logs/ root but it's empty. I used FSMonitor to watch my file system as I signed into the SSO plugin and found that it's writing domain data to
~/Library/Group Containers/group.com.apple.KerberosExtension/Library/Preferences/group.com.apple.KerberosExtension.plist
The ~/Library/Preferences/Kerberos_SSO.log file is also being touched but it remains empty (or seemingly so; cat-ing it in Terminal just shows nothing). Maybe you can grep the .plist in GroupContainers?
dmccluskey
  • July 26, 2022
i think you might be onto something
better then the log file idea.
KSSOUSERID="$(/usr/libexec/PlistBuddy -c Print /Users/$loggedInUser/Library/Group Containers/group.com.apple.KerberosExtension/Library/Preferences/group.com.apple.KerberosExtension.plist | grep acme.ORG:userName | cut -d '=' -f2 | xargs)"
then
/bin/echo "<result>${KSSOUSERID}</result>"
I use something like with intune EA
AADUSERID="$(/usr/libexec/PlistBuddy -c Print /Users/$loggedInUser/Library/Application\\ Support/com.microsoft.CompanyPortalMac.usercontext.info | grep aadUserId | cut -d '=' -f2 | xargs)"
if [[ "${AADUSERID}" == "" ]] ;
then
/bin/echo "<result>${AADUSERID}</result>"
but it doesnt work
Im not sure if its because the grep key has a : in it
acme.ORG:userName
dmccluskey
  • July 26, 2022
  • July 26, 2022
There's also the /usr/bin/app-sso binary, which can output information about who is logged in. But I think it has to be run as the logged in user to get the proper information.
If you want to use that plist though, nothing wrong with that. However, you shouldn't need to use PlistBuddy for reading it, defaults should work fine as it's a pretty flat plist structure. If you know that the REALM details are always going to be the same, something like this should work
/usr/bin/defaults read /Users/$loggedInUser/Library/Group\\ Containers/group.com.apple.KerberosExtension/Library/Preferences/group.com.apple.KerberosExtension.plist ACME.ORG:userPrincipalName
In terms of your previous EA script attempts not working, are you sure you're allowing the Macs to submit inventory to see the results? This is a commonly overlooked step when creating EAs. They are only going to show results after an inventory submission.
dmccluskey
  • July 26, 2022
that did it
thanks guys
then
