Casper Imaging NetBoot with Lion fails
  • August 22, 2012
  • 51 views
Hi Folks,
we have a problem with Casper Imaging NetBoot on a Lion-Machine. We configure a basic OS X Lion, using System Image Utility, choose this configured Lion as the Image-Source and adding the CasperImaging Workflow to the end. We can start from this Netboot-Image, but no Launchpad, no autostart of Casper Imaging.
How do you solved it?
Thanks,
Holger
Best answer by richmac
Using the Netboot Automator action there is no longer the cool launchpad that the Netinstall creator had. You can select to have Imaging open at login in the automator action or alternatively you can login to the root account of the image and add Imaging to the login items before you create the netboot image.
  • August 22, 2012
  • August 22, 2012
Thanks! So you can choose between doing all the stuff by yourself (setting JSS-Server in CasperImaging.app, adding the app to login-items) or let the Worklow-Thingy do it for you (and pray :)
