Figma Desktop app deployment - Scripting
  • August 2, 2022
  • 17 replies
  • 400 views
We are starting to use Figma and their installer is a stub installer which is a pain. They give some very base instructions for deployment. We want to use architecture specific builds and there is a "script" for accessing those. My scripting is very basic and I need a little help with getting the resent version acquired from one command into the argument for the download command. I can run them individually without issue manually replacing the latest_version with the "latest_version"
here are the commands provided.
latest_version=$(curl -fsSL "https://desktop.figma.com/mac/version.txt")
intel_url="https://desktop.figma.com/mac/Figma-${latest_version}.zip"
apple_silicon_url="https://desktop.figma.com/mac-arm/Figma-${latest_version}.zip"
I'm missing how to get what is echoed for latest_version into the curl for each architecture. This is what I tried without success.
echo latest_version=$(curl -fsSL "https://desktop.figma.com/mac/version.txt") | curl -O -k https://desktop.figma.com/mac/Figma-${latest_version}.zip
Any pointers for the right direction are appreciated.
garybidwell
  • August 3, 2022
personally I just use DataJAR's autopkg recipe for Figma as it will create a installer with both architectures in a single pkg which can be used with Jamf, Munki etc.. for deployment
https://github.com/autopkg/dataJAR-recipes/tree/master/Figma
honestpuck
  • August 3, 2022
I saw the post title in the post list and had exactly the same thought.
  • August 3, 2022
Thanks for the pointer. I was thinking the script might save some packaging when there is a update. Using Auto pkg is a good place to start, I will check out that recipe.
AVmcclint
Forum|alt.badge.img+21
  • August 3, 2022
If you're still interested in a script to download the architecture specific versions of apps, you can use this as a guide. This one handles .zip files. If you are trying to download apps that come in .dmgs, the process is similar but you have to add code for handling the dmg.
#!/bin/bash # hardware architecture check. Possible answers are "arm" or "i386" CPU=$(uname -p) echo "hardware architecture is $CPU . Installing $CPU version of Figma" latest_version=$(curl -fsSL "https://desktop.figma.com/mac/version.txt") apple_silicon_url="https://desktop.figma.com/mac-arm/Figma-${latest_version}.zip" intel_url="https://desktop.figma.com/mac/Figma-${latest_version}.zip" if [[ -e /Applications/Figma.app ]]; then rm -Rf /Applications/Figma.app/ else echo "Figma is not present" fi # arm64 installation arm_install() { curl -L $apple_silicon_url > /Users/Shared/Figma-${latest_version}.zip unzip /Users/Shared/Figma-${latest_version}.zip -d /Applications/ sleep 3 rm -Rf /Users/Shared/Figma-${latest_version}.zip } # intel installation intel_install() { curl -L $intel_url > /Users/Shared/Figma-${latest_version}.zip unzip /Users/Shared/Figma-${latest_version}.zip -d /Applications/ sleep 3 rm -Rf /Users/Shared/Figma-${latest_version}.zip } if [ "$CPU" == arm ] then arm_install else intel_install fi echo "Finished installing $CPU version of Figma" exit 0
  • August 4, 2022
Thanks for that, wish I was better at scripting. I will report back which direction we go once it is implemented.
  • January 18, 2023
How this script will work if Figma is running. How I will kill the process. I create a package via .dmg with composer but now it is not working after upgrade to Ventura. it is getting Figma desktop app is corrupted. But workaround if we rightclick on the icon from dock and then click open that start working and this need to do only 1st time, which is wired. any suggestion.
AVmcclint
  • January 18, 2023
You can get highly detailed in how to kill the Figma app, but the simplest way I have found is to add
killall Figma
right before the
section of the script. If Figma isn't running, the command will just fail silently. If Figma is running, it will kill the process and make for a safe install.
  • January 19, 2023
The way I deploy
1. Download the latest version as .dmg
2. Copy that .app to application folder and package through composer
3. change the ownership of the app
4. Add a script to kill running app
5. Deploy through policy that resolve the issue.
  • June 6, 2023
We ended up using the script above pretty much as is to deploy the app. Works good but there is no update functionality. The Figma site says to create a Figma group with users and change the app permissions for that group to be allowed Auto update functionality. That would be a pain in my opinion. I think adding a version checker to the script above would be a better way to do that and have the Policy with the script run weekly to check any version difference. Maybe I just need a version checker script separate that will add to a Smart Group that has the original script scoped. Just thinking out loud here, but how do you update Figma?
AVmcclint
  • June 6, 2023
What I did was to put the script in a payload-free package (https://github.com/rtrouton/Payload-Free-Package-Creator) and uploaded to Jamf. Then I created a patching policy for Figma. When I see there's a new version, I define the next patch using the exact same package. When Jamf detects that a user has an older version of Figma, it will "install" the package that only runs the above script that goes out and grabs whatever the latest version is since the download path for the current version stays the same. The only manual part is just paying attention to when Patch Management so I can create a new definition.
AVmcclint
  • November 16, 2023
I have discovered that the version number that Figma puts on https://desktop.figma.com/mac/version.txt is not updated in sync with the actual latest version that is available for download from their download page. After going back and forth with their support I got the following response:
Thanks for your patience here. The engineers have confirmed that it's expected that version.txt is the last place we update our version information. This is because we wait to update version.txt until the new version is fully rolled out so that admins can be confident that any unexpected issues have been resolved before they upgrade.
If you've ever seen this data out of sync by more than one version, please let me know and I'll double-check again with them on what might be needed to prevent this confusion.
They also noted that they're planning for more changes in future to better support enterprise rollouts including the possibility of a an RSS feed that admins can watch for updates and so they hope the enterprise deployment experience should continue to improve over the coming months.
So what I did then was to make a launchAgent for myself to run locally on my Mac once an hour that runs a script in my /Library/Company/scripts/ folder that will compare the version of Figma that I have installed on my Mac with the version that is listed on their version.txt file on the Figma site. If the version in the version.txt page is newer than the version on my Mac, it will pop up a notification letting me know.
Here is the LaunchAgent that goes in ~/Library/LaunchAgents/ :
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>Label</key> <string>com.company.figma.version</string> <key>ProgramArguments</key> <array> <string>/bin/sh</string> <string>/Library/Company/Scripts/Figma_version_check.sh</string> </array> <key>RunAtLoad</key> <true/> <key>StartInterval</key> <integer>3600</integer> </dict> </plist>
 Here is the script that goes in /Library/Company/Scripts/ :
#!/bin/bash # Check if Figma is installed in /Applications FIGMA_APP="/Applications/Figma.app" # URL of the Figma version.txt file FIGMA_VERSION_URL="https://desktop.figma.com/mac/version.txt" # Path to the JamfHelper binary (make sure it's installed) JAMF_HELPER="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper" # Check if Figma is installed if [ -d "$FIGMA_APP" ]; then # Get the installed version of Figma INSTALLED_VERSION=$(/usr/bin/defaults read "$FIGMA_APP/Contents/Info.plist" CFBundleShortVersionString) # Fetch the remote version from the website REMOTE_VERSION=$(curl -s "$FIGMA_VERSION_URL") echo $REMOTE_VERSION # Compare versions using awk if [[ $(echo "$INSTALLED_VERSION" | awk -F. '{ printf("%03d%03d%03d\\n", $1, $2, $3); }') -lt $(echo "$REMOTE_VERSION" | awk -F. '{ printf("%03d%03d%03d\\n", $1, $2, $3); }') ]]; then # Display a message using JamfHelper "$JAMF_HELPER" -windowType utility -title "Figma Update Available" -icon "$FIGMA_APP/Contents/Resources/electron.icns" -description "There is a new version of Figma available. Please download the update." -button1 "OK" -defaultButton 1 else echo "Figma is up to date." fi else echo "Figma is not installed in /Applications." fi
When I get the notification that there is an update available, then I update the Patch Policy in Jamf for that new version. This works for me at least until Figma changes their "enterprise deployment experience".
  • January 24, 2024
Could the script above that you are putting in Company/Scripts be made into an extension attribute? Then you could set the application install policy Ongoing and scope it to a "Figma Out of Date" smart group?
  • January 24, 2024
An EA to check for the latest version of Figma compared to what @erichughes  👍
#!/bin/bash # Get the current version of Figma installed on the device installedVersion=$(defaults read /Applications/Figma.app/Contents/Info.plist CFBundleShortVersionString) # Get the latest version of Figma available from the website latestVersion=$(curl -s https://desktop.figma.com/mac/version.txt) # Compare the installed version to the latest version if [ "$installedVersion" == "$latestVersion" ]; then echo "<result>Latest Version Installed</result>" else echo "<result>Outdated Version Installed</result>" fi
  • January 24, 2024
Added an additional step to check if Figma is installed @erichughes
#!/bin/bash #Check to see if Figma is installed if [ -d "/Applications/Figma.app" ]; then #Get the version of Figma installed figmaVersion=$(defaults read /Applications/Figma.app/Contents/Info.plist CFBundleShortVersionString) #Get the latest version of Figma from the website latestVersion=$(curl -s https://desktop.figma.com/mac/version.txt) #Compare the versions if [ "$figmaVersion" = "$latestVersion" ]; then echo "<result>Latest Version Installed</result>" else echo "<result>Outdated Version Installed</result>" fi else echo "<result>Figma Not Installed</result>" fi
  • February 20, 2024
Thanks for the EA. I'll test that in my environment. Basically just want it to populate a smart group scoped to the policy containing the installer script, so it shows up in self service when a update is available.
Low73
  • January 30, 2026
Hey i know it’s been a while but here is the script I use
i didn’t tried to update yet
cheers guys
# Affiche toutes les commandes et arrête en cas d'erreur critique
set -euo pipefail
IFS=$'\n\t'
# Détection architecture: "arm" (Apple Silicon) ou "i386" (Intel)
CPU=$(uname -p)
echo "Architecture matérielle détectée : ${CPU}"
# Récupère la dernière version de Figma
echo "Dernière version Figma : ${latest_version}"
# Supprime l'app existante si présente
if [[ -e "/Applications/Figma.app" ]]; then
echo "Figma.app détectée, suppression en cours…"
rm -rf "/Applications/Figma.app/"
echo "Figma n'est pas présent dans /Applications."
# Fonctions d'installation
arm_install() {
echo "Téléchargement Figma Apple Silicon (ARM) depuis : ${apple_silicon_url}"
curl -L "${apple_silicon_url}" -o "/Users/Shared/Figma-${latest_version}.zip"
echo "Décompression dans /Applications…"
unzip -o "/Users/Shared/Figma-${latest_version}.zip" -d "/Applications/"
sleep 3
rm -f "/Users/Shared/Figma-${latest_version}.zip"
intel_install() {
echo "Téléchargement Figma Intel depuis : ${intel_url}"
curl -L "${intel_url}" -o "/Users/Shared/Figma-${latest_version}.zip"
sleep 3
# Choix de l'install selon l'architecture
if [[ "${CPU}" == "arm" ]]; then
arm_install
intel_install
echo "Installation terminée pour l’architecture ${CPU} (Figma ${latest_version})."
  • January 30, 2026
This is part of Mac Apps now, just saying
