Set DNS - "not running"
  • August 3, 2022
  • 30 views
Hi All,
I am trying to set all my laptops DNS servers to Cloudflares. I set a test policy which does this:
I see it on my test laptop, but its showing as "not running". Is there a permission or something I need to invoke it?
  • August 4, 2022
No thoughts from anyone?
  • September 9, 2022
I'm having the same issue and found your thread. If you did find a solution let me know, otherwise I might put in a ticket with Jamf Support to see if they're aware of any issues.
Edit: Figured it out. The issue is the DNS payload is ignored when you have a content filter payload already deployed. In our case, it was Cisco AnyConnect, and removing it allowed the DNS filter to activate. It was listed as a known issue here: Known issues with iOS/macOS system Encrypted DNS (DoH) support - Troubleshooting - NextDNS Help Center
