Disabling the "Limit IP Address Tracking" feature in Monterey?
  • August 9, 2022
  • 22 replies
  • 1002 views
johntgeck
For safety and sanity, we'd like to be able to disable this feature on in our fleet. I couldn't find any documentation on a configuration profile payload or policy setting or even a homebrew script to disable this feature. A config profile would obviously be best as it would prevent the users from re-enabling. An ongoing policy that uses either a script or an actual policy payload would be... fine I guess, but less preferred as between recurring checkins the user could do whatever they wanted.
Does anyone have any resources on this?
Best answer by talkingmoose
You mention “for safety and sanity”, but I’m curious what you mean by that? When enabled, this feature protects the end user’s privacy, and it only applies to Internet trackers within the Mail and Safari apps.
Jamf Pro already collects IP address information (both public and internal). What more are you after by trying to disable this feature?
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • August 9, 2022
johntgeck
  • August 9, 2022
Hah. Of course. I thought it was obfuscating the IP address at a network level, but that wouldn't make any sense. I think I was getting it confused with the "Private wi-fi address" setting on iOS. So this feature is only for those specific applications? How does that look on a network level? Is it running the traffic through a relay after it goes outside of our network or something? If you have a resource on how/what the feature actually does that I can read up on, I would appreciate it.
talkingmoose
  • Community Manager
  • August 9, 2022
Just those two apps according to the tiny text below the feature.
I can’t vouch for the accuracy of this post, but it makes sense to me. To limit IP address tracking, Apple would need to relay all Mail and Safari traffic through their servers. And it wouldn’t stop the most common form of tracking for email, which is an embedded personalized tracker in a link.
https://discussions.apple.com/thread/253657312
  • August 18, 2022
Actually, just going back to the original question, is there a scripting/profile means to turn it off. If it always worked, it would be fine. It doesn't.
So, only Apple Mail/Safari. With the feature enabled and connected to a Verizon MiFi hotspot "nslookup google.com" from Terminal...
/AppleInternal/Library/BuildRoots/20d6c351-ee94-11ec-bcaf-7247572f23b4/Library/Caches/com.apple.xbs/Sources/bind9/bind9/lib/isc/unix/socket.c:2132: internal_send: fe80::dcaa:ccff:fe30:1e72%5#53: Network is down
Disable the feature and...
[2:35 PM] Scott, Anthony C. (MSFC-IS50)[Leidos, Inc.]
MSLAL0819110336:~ acscott2$ nslookup google.com
Server:        8.8.8.8
Address:    8.8.8.8#53
Non-authoritative answer:
Address: 142.250.9.113
Address: 142.250.9.101
Address: 142.250.9.100
Address: 142.250.9.102
Address: 142.250.9.139
Address: 142.250.9.138
So back to the original question, how can we disable this in mass.
  • September 21, 2022
Server:        8.8.8.8
Address:    8.8.8.8#53
Did you ever get anywhere on this? We also need to disable as it is causing DNS issues on our network.
  • October 4, 2022
I have seen issues with NoMAD not working correctly when this is enabled.
  • October 5, 2022
Sadly, nothing. It is really annoying and hits people when they travel since it is a new WiFi.
akamenev47
  • October 20, 2022
We see issues with FortiClient AV/web filter + the "Limit IP Address Tracking" checked, had a few successful results when users manually would uncheck the feature and the network issues would stop.
Would be nice to know if there is a way to uncheck this via script, but I have a suspicion - since this is a privacy feature - Apple hid it, as I was unable to find it anywhere in any of the plist files related to Network/WiFi...
  • December 12, 2022
Anyone have any luck finding a solution to this that isn’t just have the end-user disable it?
This feature seems to be much more aggressive in macOS Ventura and iPadOS 16 to the point it’s causing issues with pages loading with an in-line firewall appliance.
Disabling Private Relay can be achieved by a MDM Profile and at the network DNS level, however this feature (Limit IP Address Tracking) functions independently of these. All a profile does is remove it as a configurable option within a user iCloud settings (which isn’t even in use).
  • December 12, 2022
I hope everyone that is having this issue is using Feedback Assistant to offer feedback as this is really not a friendly thing for Apple to do. It ends up that they end up being able to stop any site they want using their DNS system over a DNS system of our choice. If it only did what it said it did and only affected Mail and Safari, it would be annoying, but since it affects other programs, it is pretty sleazy. Almost scream spyware.
JevermannNG
  • September 12, 2023
I have the "feeling" that the impact of this setting is deeper. Today it turned out, that a Mac with active "Tracking Limit" Option was not accepted by our Firewall and could not reach our Intranet ...
JevermannNG
I am pretty sure that this option has a bigger impact on other network services like VPN etc.
Perhaps, but anyway you look at it, when Apple adds a new feature, they need to provide a means to disable it via a profile. I say this as it has been pretty rare for Apple to get it right on the first try for quite some time now.
  • September 13, 2023
We are experiencing problems that disabling IP address tracking resolves; The problem was minimized for a while however with devices updating to 13.5.1 and 13.5.2 the problems have escalated once again.  No command, plist, nor profile seems to be found on the www's and reviewing any preference files and commands is coming up short too.
This is a different solution, however I'll document here for the record: https://www.kolide.com/features/checks/mac-disable-icloud-private-relay
This is what I got from JAMF Support:
Thank you for your patience! So, I found something that might help us out here. Please take a look at this article: https://macblog.org/disable-icloud-private-relay/.
It looks like "Limit IP Address Tracking" might be able to be disabled by disabling the iCloud private relay with a configuration profile.
JevermannNG
  • September 14, 2023
Thank you for the links, we will start monitoring the activation of iCloud Private Relay now. It looks like that the Tracking Protection in the network settings only has an impact when Private Relay is active ...?
Yes, looks like this is only possible and even questionable under 13.5.2 (I'm still investigating).
Sadly there is also not a way to admin this per SSID which is in the interface.
JevermannNG
  • September 15, 2023
Please review: https://www.kolide.com/features/checks/mac-disable-icloud-private-relay
Can anyone confirm that this Config Profile still works under macOS 13.5.2 ? It looks like that the option is still available, at least the activated check box still shows up.
Thank you!
walkeri3rd
  • October 18, 2023
Has there been head way made on this. We are have big issues with Untrusted IPs with Students and Teachers.
JevermannNG
  • October 19, 2023
We use the Configuration Profile from the following site and it solved our issues:
https://www.kolide.com/features/checks/mac-disable-icloud-private-relay#how-to-block-icloud-private-relay
Thanks to @applebit  for providing the link!
  • October 14, 2024
IT blocks access to locally hosted websites and prevents access to external services providers who limit block access by IP address.
