My question may have a ridiculously easy answer, but here goes. We have a lab environment with a teacher who works with grades Pre-K, K, 1, 2, 3.
We have user accounts (standard user accounts in AD for these grades).
The teacher wanted to have a specific dock configuration for these standard user accounts. After looking at a bunch of options I went with Dockutil.
A friend of mine with considerably more scripting experience helped me create a single script that used case to configure the dock for those specific user accounts.
The trouble is that script was made before Dockutil was rebuilt using Swift. How do I adapt the script to work now without Python??
The script is below:
#We need to wait for the dock to actually start
until [[ $(pgrep Dock) ]]; do
wait
done
#Get the current logged in user that we'll be modifying
if [ ! -z "$3" ]; then
user=$3
user=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "\\n");')
#Set variables
du="/usr/local/bin/dockutil"
userHome="/Users/$user"
networkHome="smb://server.com/Students$/$user"
#Function for applying dock configuration
createBaseDock()
#Remove all items for logged in user
$du --remove all --no-restart $userHome
#Adding base items to the dock
$du --add '/Applications/Google Chrome.app' --position 1 --no-restart $userHome
$du --add '/Applications/Safari.app' --position 2 --no-restart $userHome
$du --add '/Applications/Comic Life 3.app' --position 3 --no-restart $userHome
$du --add '/Applications/The Print Shop 4.app' --position 4 --no-restart $userHome
$du --add '/Applications/KID PIX.app' --position 5 --no-restart $userHome
#Function for finishing base dock
finishBaseDock()
#Add local downloads
$du --add '~/Downloads' --section others --position last --no-restart $userHome
killall Dock
case $user in
p|k)
echo "p or k found"
createBaseDock
finishBaseDock
1)
echo "1 found"
createBaseDock
$du --add '/System/Applications/Photo Booth.app' --position 6 --no-restart $userHome
finishBaseDock
2)
echo "2 found"
createBaseDock
finishBaseDock
3)
echo "3 found"
createBaseDock
$du --add '/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app' --position 7 --no-restart $userHome
finishBaseDock
esac
Use the following to get the logged in user. The python method was tried and true for many years and this is the modern replacement.
https://scriptingosx.com/2020/02/getting-the-current-user-in-macos-update/
user=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name 😕 && ! /loginwindow/ { print $3 }' )
I figured it was probably something simple, to someone (not me) who is fluent in scripting. Thank you! :-)
Below is the revised script with the change you suggested, look right?
wait
done
user=$3
#Set variables
createBaseDock()
finishBaseDock()
killall Dock
case $user in
p|k)
echo "p or k found"
createBaseDock
finishBaseDock
1)
echo "1 found"
createBaseDock
finishBaseDock
2)
echo "2 found"
createBaseDock
finishBaseDock
3)
echo "3 found"
createBaseDock
finishBaseDock
esac
wait
done
user=$3
#Set variables
createBaseDock()
finishBaseDock()
killall Dock
case $user in
p|k)
echo "p or k found"
createBaseDock
finishBaseDock
1)
echo "1 found"
createBaseDock
finishBaseDock
2)
echo "2 found"
createBaseDock
finishBaseDock
3)
echo "3 found"
createBaseDock
finishBaseDock
esac
I made some changes to your script because repetition is discouraged in coding (DRY: Dont Repeat Yourself).
In your `case` statement, you were running a `createBaseDock` and a `finishBaseDock` with each case but you can just run the create before the case check and the finish one after.
wait
done
user=$3
#Set variables
createBaseDock()
finishBaseDock()
killall Dock
createBaseDock
case $user in
p|k) echo "p or k found";;
1) echo "1 found"
$du --add '/System/Applications/Photo Booth.app' --position 6 --no-restart $userHome;;
2) echo "2 found"
3) echo "3 found"
$du --add '/Applications/Adobe Photoshop 2020/Adobe Photoshop 2020.app' --position 7 --no-restart $userHome;;
esac
finishBaseDock
@Tangentism THANK YOU!!!! Works great!!!!
@cbrewer THANK YOU! Just wanted to be sure an acknowledge that your solution worked and to of course thank you :-)
