I'm testing out the self service software update feature - but it seems
like it's doing stuff, then just stops. The progress bar on the self
service window is about 50% complete, but there hasn't been any updates
in the install.log file for over 10minutes. End users that have tried
it have reported similar issues (bar gets to about 50% then doesn't move
after that).
It happens on 10.6 and 10.7 systems, is there another log file I may be
missing that could have more detailed info?
John Wojda
Lead System Engineer, DEI & Mobility
3333 Beverly Rd. B2-338B
Hoffman Estates, IL 60179
Phone: (847)286-7855
Page: (224)532.3447
Team Lead DEI: Matt Beiriger
<mailto:mbeirig at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.>
Team Lead Mobility: Chris
<mailto:cstaana at searshc.com;jwojda at searshc.com?subject=John%20Wojda%20Fe
edback&body=I%20am%20contacting%20you%20regarding%20John%20Wojda.> Sta
Ana
Mac Tip/Tricks/Self Service & Support
<http://bit.ly/gMa7TB>
"Any time you choose to be inflexible in your approach to an
unpredictable project you are already building failure into your plan"
