I need help with Trusting Certificates on both Laptops and IPads
  • September 27, 2022
  • 41 views
Hello All,
I am in need of assistance in regards to Trusting CA's on both Laptops and IPads,
I been trying it via Configuration Profile, yet when scoping it the fleet of Laptops and Ipads, they seem to Fail to install,
below are screenshots of the configure, any suggestions will be beneficial.
(sorry for the links i dont yet have permissions to upload photos)
Network Configuration
and in the Certificate section i have uploaded the 2 certificates, would anyone know whats going on?
The Laptop Configuration and Ipad Configuration are pretty much identical, and they both have the same issues
Thanks
Error in Logs Just say "Failed"
You need to add an FQDN under "Trusted Common Name", e.g. *.radius.company.com
