So i was reading another thread https://jamfnation.jamfsoftware.com/discussion.html?id=3792 and @rpg mentioned something about block copies & ssd's dont play well together but didn't elaborate.
The reason I ask is because i just set our finalized "standard" MBP as the Retina w/ SSD.
What issues am I going to run into because of this? Was this resolved in Casper 8.6? I guess I haven't had a problem with the MBAirs, but I have noticed that since I made a custom NBI with the 2012 MBAirs if I diskutil eraseVolume on the drives I can only do one partition, then it gives an error about not able to unmount the drive when I try to do another partition. If I reboot then I can do the 2nd partition.
