Can I have multiple Pre-stage enrollments that auto Enroll
  • October 14, 2022
  • 40 views
I have several Pre-Stage enrollments for devices and ant to make it so that iPads auto enroll in one and Apple TV's Auto-enroll in another.  Is there a function to do this?  I can't find anything.
1 reply
ENGlockling
  • October 14, 2022
You could replicate the current MDM server that you've setup in ABM so that iPads are auto-assigned to one and Apple TV's auto-assigned to the other. Then you would have two ADE instances (with unique tokens) in Jamf Pro, which you can then target to auto-assign devices to in each PreStage enrollment. (Prestage#1 for iPads assigned to ADE instance#1, Prestage#2 for Apple TV's assigned to ADE instance#2)
