Disable True Tone and Auto Brightness with a script
  • October 25, 2022
  • 5 replies
  • 96 views
Blackground :
We deal with lots of designers and video editors at my company and they can't do a proper white balance with True Tone. As far as I know, there is no MDM key to manage this setting.
Solution :
I created an Apple Script (embedded in a bash script) that will open and automatically click the right menus in order to turn off True Tone and Auto Brightness. It only works with an English UI but you'll find a French version on my website. It was written for macOS Monterey and Ventura.
Scripts : disable_truetone_english.sh
Blog post : https://clementine.la/scripts/desactiver-true-tone-par-script/
#!/bin/bash ### # # Author : https://clementine.la # Created : 2022-09-09 # Last Modified : 2022-10-24 # Version : 2.0 # Tested with : macOS 12.6 / macOS 13.0 # ### # Read logged in user loggedInUser=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }') echo "Hello, I am $loggedInUser" # Read macOS version macos=$(sw_vers -productVersion) ############# # FUNCTIONS # ############# # Disable True Tone & Auto Brightness # Doesn't work if you have an external monitor plugged in truetone_monterey() { open "/System/Applications/System Preferences.app" sleep 3 open "/System/Library/PreferencePanes/Displays.prefPane" sleep 1 sudo -u "$loggedInUser" osascript -e ' activate application "System Preferences" tell application "System Events" tell process "System Preferences" repeat until exists group 1 of window "Displays" end repeat if (value of checkbox "Automatically adjust brightness" of group 1 of window "Displays" as boolean) then click checkbox "Automatically adjust brightness" of group 1 of window "Displays" end if if (value of checkbox "True Tone, Automatically adapt display to make colours appear consistent in different ambient lighting conditions." of group 1 of window "Displays" as boolean) then click checkbox "True Tone, Automatically adapt display to make colours appear consistent in different ambient lighting conditions." of group 1 of window "Displays" end if end tell delay 1.0 quit application "System Preferences" end tell ' } truetone_ventura() { open "/System/Applications/System Settings.app" sleep 3 open "/System/Library/PreferencePanes/Displays.prefPane" sleep 1 sudo -u "$loggedInUser" osascript -e ' activate application "System Settings" tell application "System Events" tell process "System Settings" repeat until exists group 1 of window "Displays" end repeat if (value of checkbox 1 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays" as boolean) then click checkbox 1 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays" end if if (value of checkbox 2 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays" as boolean) then click checkbox 2 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays" end if end tell delay 1.0 quit application "System Settings" end tell ' } ################# # END FUNCTIONS # ################# if [[ "$macos" == "12."* ]]; then echo "MONTEREY" truetone_monterey elif [[ "$macos" == "13."* ]]; then echo "VENTURA" truetone_ventura else echo "UNKNOWN OS" exit 0 fi exit 0
  • December 9, 2022
I'm getting an error when I run it.
587:594: execution error: System Events got an error: Can’t get checkbox 2 of group 2 of scroll area 2 of group 1 of group 2 of splitter group 1 of group 1 of window "Displays" of process "System Settings". Invalid index. (-1719)
  • December 9, 2022
Worked great on a machine with Auto Brightness and True Tone.  Maybe thats the issue my iMac doesn't have True Tone. Thanks for this it's exactly what I needed!
  • December 11, 2022
The script is not really robust I admit, it expects the 2 settings in the opened window. If you want to keep True Tone on or if your Mac doesn't support it, you can remove the following lines from the script :
  • January 3, 2023
Any solution if we have 2 displays running?
  • February 20, 2024
Hi! Thanks for the script! Is there any way I can launch it via Shortcut?
I tried pasting the script or launch it via file (chmod +x), doesn't work
