Ventura reporting as 13.0 instead of 13.0.0
  • October 26, 2022
  • 7 replies
  • 88 views
Running 10.42, has any one else testing Ventura seen a device entry revert to using OS version 13.0 instead of 13.0.0? This occurs at some random point after the device has done a successful recon to report as 13.0.0. A subsequent recon or inventory update corrects this version. I've only seen this so far on a device that went from 12.6.1 > 13.0.0 and have not yet seen it occur on a device that was setup in place from 13.0.0, but still fairly early in testing.
  • October 26, 2022
For what its worth I was able to replicate this on a second device upgraded from Monterey to Ventura (Intel and M1).
Jason33
  • October 26, 2022
On an M1 that I updated yesterday the version shows 13.0.0, and on an Intel machine that I updated just now it shows 13.0.  The only difference that I know between the two was the M1 was running the beta, then RC1 - RC2.
  • October 26, 2022
I've had it occur on both Intel and M1s so far, and neither from an RC juts from 12.6.1. I've a case open with support but wanted to see if others might be seeing similar. The real issue is that it breaks out smart groups for profile deployment when a devices shows as 13.0 instead of 13.0.0 so a number of config profiles remove and then need to be reapplied.
Jason33
  • October 27, 2022
My systems, including the Intel that previously showed as 13.0, now all show 13.0.0.  How is your Smart Group criteria set?  I have mine for Operating System Version Like 13, and this pulled both 13.0 and 13.0.0 correctly in to the group.
  • October 27, 2022
Using a regex matchs for 11.[0-9].0-9]|12.[0-9].[0-9]|13.[0-9].[0-9]. I can add a line to evaluate for 13.0 but I'd prefer to keep them clean and uniform when at all possible.
  • October 27, 2022
I've seen the OS version data alternating back and forth between 13.0 and 13.0.0 on the handful of machines that have updated to Ventura in my org so far. I posted about it on /r/jamf and got this explanation:
"Jamf Pro 10.42.0 includes Declarative Device Management. When the `jamf` binary submits inventory, it drops the trailing `.0`; when DDM sends an autonomous update, it sends the raw data, `13.0.0`."
So it seems that they need to update the jamf binary to no longer truncate that last ".0" so both means of updating machine info are reporting identically-formatted data.
emily
  • October 31, 2022
Just thought I'd share some digging that I've done here. If you turn on debug on your server logging you'll see ddm status channel updates, like this one:
2022-10-31 20:06:54,624 [DEBUG] [ina-exec-35] [larativeManagementRequest] - Declarative Management check-in with endpoint status and data { "StatusItems" : { "management" : { "declarations" : { "activations" : [ { "active" : true, "identifier" : "scrubb3d", "valid" : "valid", "server-token" : "scrubb3d" } ], "configurations" : [ { "active" : true, "identifier" : "scrubb3d", "valid" : "valid", "server-token" : "scrubb3d" } ], "assets" : [ ], "management" : [ { "active" : false, "identifier" : "scrubb3d", "valid" : "valid", "server-token" : "scrubb3d" }, { "active" : false, "identifier" : "scrubb3d", "valid" : "valid", "server-token" : "scrubb3d" } ] }, "client-capabilities" : { "supported-versions" : [ "1.0.0" ], "supported-payloads" : { "declarations" : { "activations" : [ "com.apple.activation.simple" ], "assets" : [ ], "configurations" : [ "com.apple.configuration.legacy", "com.apple.configuration.legacy.interactive", "com.apple.configuration.management.status-subscriptions", "com.apple.configuration.management.test", "com.apple.configuration.passcode.settings" ], "management" : [ "com.apple.management.organization-info", "com.apple.management.properties", "com.apple.management.server-capabilities" ] }, "status-items" : [ "device.identifier.serial-number", "device.identifier.udid", "device.model.family", "device.model.identifier", "device.model.marketing-name", "device.operating-system.build-version", "device.operating-system.family", "device.operating-system.marketing-name", "device.operating-system.supplemental.build-version", "device.operating-system.supplemental.extra-version", "device.operating-system.version", "management.client-capabilities", "management.declarations", "test.array-value", "test.boolean-value", "test.dictionary-value", "test.error-value", "test.integer-value", "test.real-value", "test.string-value" ] }, "supported-features" : { } } }, "device" : { "operating-system" : { "version" : "13.0", "build-version" : "22A380" } } },
And if you run a recon locally, you'll see the following:
Locating hardware information (macOS 13.0.0)...
So it looks like ddm reports 13.0 and the Jamf management framework reports 13.0.0.
We're seeing the same behavior on computers running the 13.1 beta (flapping between 13.1 and 13.1.0).
