Smart group for Latest Version of Application
  • October 31, 2022
  • 7 replies
  • 98 views
Hello All,
Can we create a Advance Search or a smart group to list of Not or Either latest version of an application.
Tried this combination but result null.
Application Title    has      Microsoft Outlook.app
and
Application Version    is not    Latest Version
Not sure where I'm doing wrong.
Best answer by jtrant
You'll need to add Microsoft Outlook as a Patch Management title, and use that in your smart group. "Application Version" expects a version number or regex.
  • October 31, 2022
Forum|alt.badge.img+15
  • October 31, 2022
I prefer regex for this.
Use the following script to help generate the regex:
https://gist.github.com/talkingmoose/2cf20236e665fcd7ec41311d50c89c0e
Then create a smart group like so:
  • October 31, 2022
@cbrewer- Sure, but what happens when Outlook gets updated? Using a Patch Management title will avoid having to change anything later down the line.
Regex is awesome, but really only when you have a target version in mind.
  • October 31, 2022
Thank you, I will go through this too.
  • October 31, 2022
If understated correctly, you should be able to let patch reporting work for you:
PatchReporting Outlook   less than  Latest Version is what we use, seems to work for our needs
  • October 31, 2022
This is what I described above and in my screenshot, and works perfectly here too.
  • November 17, 2023
I've never seen this done. I might try this in a test enviroment for my new prestage I'm creating with JAMF Connect 2.27.0 being installed at enrollment. Then apply the smart group to push 2.29.0. This regex looks promising.
