Change computer name to username-serialnumber
  • November 14, 2022
  • 8 replies
  • 72 views
Hi everyone
Can someone suggest me a good script to change my mac's name to "username-serialnumber" ?
Thanks
Best answer by karthikeyan_mac
@Philein You can scutil or jamf binary
#!/bin/bash serialNumber=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}') loggedinuser=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }' ) name=$loggedinuser-$serialNumber scutil --set HostName $name scutil --set LocalHostName $name scutil --set ComputerName $name
or you can also use Jamf binary instead of scutil.
jamf setComputerName -name $name
 Thanks
karthikeyan_mac
Forum|alt.badge.img+20
  • November 14, 2022
 Thanks
markdmatthews
  • November 14, 2022
you're also going to need to add:
/usr/local/jamf/bin/jamf recon
or a Maintenance to the policy to update Jamf
  • November 14, 2022
 Thanks
Thanks. It works but it returns me this:
Script exit code: 0
Script result: SCPreferencesSetLocalHostName() failed: Invalid argument
markdmatthews
  • November 14, 2022
Script exit code: 0
I do this...
### Get serial number
serial=`/usr/sbin/system_profiler SPHardwareDataType | /usr/bin/awk '/Serial\\ Number\\ \\(system\\)/ {print $NF}'`
/usr/sbin/scutil --set ComputerName "${serial}"
/usr/sbin/scutil --set LocalHostName "${serial}"
/usr/sbin/scutil --set HostName "${serial}"
Forum|alt.badge.img+21
  • November 14, 2022
This is a good time to point out that PII in a device name is generally not a good idea.  Device names are broadcast in the clear on public networks, and personally identifiable information could be a security and/or safety risk.  If your users are adults, you're probably ok, but I would definitely NOT recommend this for K12 devices.
Just my $0.0.2
  • November 14, 2022
Just my $0.0.2
Thanks, this is a valid point.
karthikeyan_mac
  • November 15, 2022
Script exit code: 0
@Philein LocalHostName cannot have space dots. If your username has dot you may have to remove it.
loggedinuser=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }' | sed -e 's/\\.//g' )
 You can use the change the "loggedinuser"  to strip the dots from the username.
Thanks
AtillaTheC
  • December 9, 2022
We have periods in the usernames, I use this script
#!/bin/sh serial=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}') currUser=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }' | sed -e 's/\\.//g' ) name=$currUser-$serial /usr/sbin/scutil --set ComputerName $name /usr/sbin/scutil --set HostName $name /usr/sbin/scutil --set LocalHostName $name exit 0
