I've created a configuration in Casper Admin for the new iMacs I'm installing in my Communications lab. The iMacs have 1TB hard drives and need to be split in to a 1gb Restore parition, a 250gb Boot partition, and 750gb media partition. I've created the partition scheme under the Additional Partitions tab in the Configuration in Casper Admin, but the scheme does not show up when I image the machine. When I load Casper Imaging and look at the steps, I do not see a step to create the partitions in the left pane of the application. Stranger still, if I click on Custom Install and look at the tab that shows the partitions, the disk space listed is only 500gb. I'm target mode imaging over Thunderbolt if that makes any difference. I'm completely confused at this point. I must be missing something easy.
Problem partitioning during imaging
