Deploying Splashtop Streamer using Splashtop's Script - Missing Screen Recording Permissions
  • November 30, 2022
  • 71 views
I'm pretty new to Jamf Pro so please excuse my ignorance. I have Splashtop setup in Jamf Pro and the deployment works great except for the fact that screen recording it not being enabled by Splashtop's script. I tried to post the script below but it's too long. I don't see any reference to screen recording in the script but I may very well be missing something. Can anyone able to offer any insight? I'm waiting to hear back from Splashtop support on this as well.
Thank you,
-Jason
  • November 30, 2022
I am pretty sure the end user has to enable screen recording.  This is by design by Apple.  You can experiment with Configuration Profiles>Privacy Preferences Policy Control settings in the JSS so you don have to rely on scripts for PPPC settings.  You can also use the PPPC Utility to assist. https://github.com/jamf/PPPC-Utility
  • November 30, 2022
Thanks so much! Appreciate your time here.
czarmark
  • November 30, 2022
Yup anything that shares the screen or uses the microphone, Apple wants the user to have "agency" to make that choice instead of MDM. Agreed on PPPC recommendation, I used it to create two configuration profiles, one for Splashtop Streamer and one for Splashtop SOS, both with identical permissions that grant
SystemPolicyFiles: Allow
Screencapture: Allow Standard users to allow access (the user has to enable screen recording BUT won't have to click the padlock and authenticate)
AppleEvents: Allow
Accessibility: Allow.
Splashtop has a Jamf Pro deployment guide here: https://support-splashtopbusiness.splashtop.com/hc/en-us/articles/360042998132-Deployment-with-Jamf-Pro
Lastly, be aware that even though these settings will be enabled by the profile, check marks WON'T appear for these items in System Preferences > Privacy and it will throw you off at first.
