NetBoot filtering on the NetBoot/SUS appliance
  • August 6, 2012
  • 25 views
Is there any way we could do Mac Address NetBoot filtering on the NetBoot/SUS appliance?
  • August 8, 2012
Have you considered using iptables?
Just use for each host's ethernet address an allow line:
/sbin/iptables -A INPUT -p tcp --destination-port $PortToBlock -m mac --mac-source 01:23:45:67:89:AB -j ACCEPT
and further down a
/sbin/iptables -A INPUT -p tcp --destination-port $PortToBlock -j DROP
for every service you would like to filter using ethernet addresses.
  • August 9, 2012
I tried iptables but it didn't seem to stop filtered out Macs from seeing the netboot server.
What we've found works is to change the file /var/appliance/conf/dhcpd.conf
If you change the class definition from this:
class "AppleNBI-i386" {
match if substring (option vendor-class-identifier, 0, 14) = "AAPLBSDPC/i386";
To this:
match if (substring (option vendor-class-identifier, 0, 14) = "AAPLBSDPC/i386") and (
        binary-to-ascii (16,8,":",substring(hardware, 0, 7)) = "1:c4:2c:03:27:20:4f" or
        binary-to-ascii (16,8,":",substring(hardware, 0, 7)) = "1:00:1f:5b:3e:66:3c"
You can add additional lines for each MAC address you want to allow to see and boot from the appliance.
