I'm running single-app mode on our iPads; using them as a display.  Occasionally, the iPad loses internet connection and then show the error message "Error: The Internet Connection Appears to be Offline".  I've disabled the touch screen so users are unable to clear this message until I disable single-app mode, clear the message, then re-enable single-app mode.
Can I add a configuration payload that blocks this error message?  Or, is there a way to automatically clear it?
Be the first to reply!
