SentinelOne Agent Installation
  • January 10, 2023
  • 9 replies
  • 961 views
Good afternoon JAMF Nation. Just want to get your professional guide/advice on how to install the SentinelOne agents in our MacOS devices using JAMF. I have the PKG file needed but when I tried installing it as normal, it failed. Looking for a friend, TIA!
Best answer by AJPinto
@AJPinto What are you doing to ensure full disk access / all other approvals?
We are using the PPPC tool, but it seems like there may still be some that are not approved by that.
SentinelOnes Documentation covers this, you need to approve three items and give them SystemPolicyAllFiles access. I honestly recommend pinging SentinelOne as they have good documentation for macOS and even have JAMF specific documentation.
Below is what I use. I always hate when people copy paste screenshots with the code requirements I needed but you cant copy it. So I put the code requirement stuff in the code blocks.
  • com.sentinelone.sentineld-shell
ID: com.sentinelone.sentineld-shell Code Requirement: anchor apple generic and identifier "com.sentinelone.sentineld-shell" and (certificate leaf[field.1.2.840.113635.100.6.1.9] /* exists */ or certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = "4AYE5J54KN") App or Service: SystemPolicyAllFiles Access: Allow
  • com.sentinelone.sentineld-helper
ID: com.sentinelone.sentineld-helper Code Requirement: anchor apple generic and identifier "com.sentinelone.sentineld-helper" and (certificate leaf[field.1.2.840.113635.100.6.1.9] /* exists */ or certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = "4AYE5J54KN") App or Service: SystemPolicyAllFiles Access: Allow
ID: com.sentinelone.sentineld Code Requirement: anchor apple generic and identifier "com.sentinelone.sentineld" and (certificate leaf[field.1.2.840.113635.100.6.1.9] /* exists */ or certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = "4AYE5J54KN") App or Service: SystemPolicyAllFiles Access: Allow
AJPinto
  • January 10, 2023
Sent1 has really good documentation for macOS and JAMF, reach out to your Sent1 rep and they should be able to get you going.
A quick over view. Sent1's package needs to be cached, and run with a script. The script contains the token sent1 needs to install. In the policy, cache the package, and run the script with a priority "after".
#!/bin/bash sudo echo "$4" > /Library/Application\\ Support/JAMF/Waiting\\ Room/com.sentinelone.registration-token sudo /usr/sbin/installer -pkg "/Library/Application Support/JAMF/Waiting Room/$5" -target /
$4 is the token
$5 is the package name
  • February 28, 2023
  • February 28, 2023
$4 is the token
Works like a charm.
AJPinto
  • February 28, 2023
  • March 6, 2023
Here is SentinelOne's official documentation.
If you follow all the steps, you will be able to install and configure everything without having end users have to approve anything.
https://usea1-012.sentinelone.net/docs/en/installing-and-upgrading-macos-kextless-agents-with-jamf.html#installing-and-upgrading-macos-kextless-agents-with-jamf
Franky779
  • January 24, 2024
I have to reply in this post. I have a problem when installing/upgrading SentinelOne via JAMF.
I followed the documentation an https://euce1-104.sentinelone.net/docs/en/installing-and-upgrading-macos-agents-with-jamf.html#UUID-0cf68a1c-dbbb-18a9-1af4-997b78637af2_UUID-aa0f809d-b41a-fbc1-e8aa-016114785721
Package is set to cached but i get an error, probably because the client ist already installed. But my testmachine has an older version then the supplied one. So it should do an upgrade? There seems to be a path problem when moving things.
Script result: installer: Package name is SentinelOne
installer: Upgrading at base path / installer: The upgrade failed. (The installation failed due to an error. Contact the software manufacturer. An error occurred while moving the files to their destination.)
Installscript
sudo echo "abcdefg" > /Library/Application\\ Support/JAMF/Waiting\\ Room/com.sentinelone.registration-token
sudo /usr/sbin/installer -pkg /Library/Application\\ Support/JAMF/Waiting\\ Room/Sentinel-Release-23-3-2-7123_macos_v23_3_2_7123.pkg -target /
  • January 30, 2024
Installscript
@Franky779 Same issue here. I'll get something started with S1 and keep y'all posted here. S1 really be breaking things lately. First (and still) locking out machines from network acces for no reason, and now this.
Franky779
  • February 5, 2024
Somehow it went through a few hours later. Still can´t see a reason yet.....but its working. Fine for me ;-)
  • February 5, 2024
Yeah for me it all of a sudden started working as well over the weekend... I think they changed something, but they still have yet to come back to me about on my support ticket. Problem solved I guess! :D
