Velociraptor deployment
  • January 17, 2023
  • 76 views
Hi, i am looking to deploy Velociraptor via Jamf and wanted to know if anyone had any experience with this? Deploying Clients :: Velociraptor - Digging deeper!
Curious what steps were taken to deploy it.
Any help is appreciated.
Thanks
TheITGuy69
  • January 17, 2023
Did you by anychance get an email from the other thread you asked information on? https://community.jamf.com/t5/jamf-pro/help-installing-velociraptor/m-p/281611#M253839
I typed up a whole bunch of stuff and then somehow it was identified as spam and they deleted it!! SMH
TheITGuy69
  • January 17, 2023
Looks like they restored my post, let me know if you have any more questions
  • January 18, 2023
thanks for all the help. The problem I am running into with this is as follows. Putting it here in case someone can help.
So I add the files in composer to /private/tmp/ and add the below post install script. I can see the machine gets the files in the folder when the policy is deployed but nothing else happens and the install does not work.
Local on the machine, if I terminal into the folder and run the same command (minus the install path since I am in the directory already) it works. I then run the chmod command and it's fine.
I must be missing something simple here. Hoping someone sees this and can help.
#!/bin/sh ## postinstall pathToScript=$0 pathToPackage=$1 targetLocation=$2 targetVolume=$3 sudo /private/tmp/velociraptor-v0.6.7-4-darwin-arm64 --config client.config.yaml service install sudo chmod -R 755 /usr/local/sbin exit 0 ## Success exit 1 ## Failure
