Inventory preload to update existing mobile device
  • January 27, 2023
  • 23 views
Hi all,
I have enrolled 25x ipad before I upload the inventory preload csv, is there a method for jamf pro to sync/update the data information from inventory preload?
  • January 27, 2023
Depending on what information was in your inventory preload you may be able to upload that data using MUT.
https://community.jamf.com/t5/jamf-pro/mut-v6-0-0-is-now-available/m-p/249861
  • January 31, 2023
Best way is to remove the current preloaded list and then use MUT to update the already enrolled devices information. If you do not remove the preloaded inventory list, next time these 25 devices when re-enrolled to Jamf will take the list's details again!
