Winclone image does not fully extract
  • August 9, 2012
  • 0 replies
  • 11 views
Hi there,
My organization is new to both Casper and Winclone, and we're running into some issues with Windows deployment. I'm following the instructions here to create Winclone images: https://jamfnation.jamfsoftware.com/article.html?id=70. However, when I try to deploy my images, they appear to only partially extract, and none of the vital folders do (system32, for example).
I've tried using compressed & uncompressed images, but the behavior is the same in both instances. If I attempt to expand the volume post-boot with Winclone, the image extracts but the system boots to a blinking cursor, even after running startup repair & bcdedit from a Windows 7 disc.
Some additional info:
Casper version 8.52
Winclone version 3.4
I did make the packages self-extracting
Images are set as OS and given priority 2 in Casper
I'm grateful for any suggestions anyone might have.
Thanks,
Rachel
