Query computer for locked or unlocked state
  • February 15, 2023
  • 44 views
Is there a way we can query a computer for its locked or unlocked state? I'm familiar with endpoints to get the command status...
  • /JSSResource/computerhistory/id/{id}/subset/commands
  • /JSSResource/computercommands/name/DeviceLock
...but neither of these tell me if the device has been unlocked after it was successfully locked
Best answer by thomasshouler
I don't know of a way to check for this state.
Truthfully though, if a device is checking in to Jamf, then it would have to be unlocked, since the nature of a locked machine is that it's not usable and wouldn't have a network/internet connection to even be able to check into Jamf Pro.
Thanks! After playing with the APIs a bit more, I noticed there's a ProfileList command that's issued immediately after a computer is unlocked. If anyone else wants to assert something similar, you can see the pattern via this endpoint: /JSSResource/computerhistory/id/{id}/subset/commands
  • February 15, 2023
  • February 16, 2023
