Hey everybody,
I need to set up a disaster recovery server for our JSS. I've looked around and I think I understand what needs to be done, I need to clarify some stuff though. The backup server will be at a different location. I know I'll need to update the DNS pointer to the backup server in the event the primary goes down. I have some questions about that.
I need to confirm, but I believe our primary server has two DNS pointers, one for hostname -> IP and one for JSS URL -> IP. Will we only need update the DNS pointer for the JSS URL? The backup server will have a different hostname but I'll set it up with the same JSS URL, right?
So the primary server will sync the database backup and CasperShare to the backup server, then if we need to swap over to the backup server all I do is run the JSS setup utility, use the same URL and update the DNS pointer.
What about the certificates? Can I use the same certificates that were on the primary server? Just copy them from Keychain Access?
Thanks for your help and please pardon any ignorance!
- Jamie
