Hello,
I am currently making a group of kiosk machines with limited functionality. essentially, they will be using square links to scan qr codes. They will not be using the square app. Is there a way through web content filtering to establish allowing all links with the beginning of https://square.link/u/ and blocking all others?
Be the first to reply!
