authorizationdb for macOS updates/upgrades
  • March 20, 2023
  • 22 views
I've seen many admins using the following command to allow non-admins to make changes to the network preferences.
security authorizationdb write system.preferences.network allow
Any of the admins here making changes to authorizationdb to allow non-admins perform software updates and upgrades?
In our org, not everyone would get local admin access and the software update seems to ask for admin credentials. If you have a working/testing (preferable for Monterey/Ventura+) version of it, can you please share?
Thanks all!
1 reply
  • March 20, 2023
Minor updates don't require admin, and as of macOS 12.3 Major ones done with the recommended Delta Update route don't either.  On Apple Silicon, updates do require a Volume Owner enter their password, but this is separate from Admin and is generally automatically given either by macOS or Jamf (via Bootstrap Token).
