Is it possible to push the Change Management Logs and Jamf Pro Access Logs to a SEIM like SumoLogic? We currently have a ComputerCheckIn webhook event that's set up to send data to SumoLogic but I don't see an option under the Webhook Event types for the two logs I mentioned above.
Page 1 / 1
You'd have to pay the like $20K for Premium cloud
If you are on JAMF Cloud, you need Premium cloud. If you are on prem you just need a tool to export the log file.
