Script to merge/override favourites not working
  • April 5, 2023
  • 36 views
Hi all,
We have this script in place to merge or override favourite servers on our clients;
#!/Library/Frameworks/Python.framework/Versions/2.7/bin/python # change the above path to your own python if you don't have Munki installed """ Merges add_servers into current favorites and removes remove_servers. Run as root to update all users or as normal user to update just that user. """ import os import getpass import subprocess import uuid import Foundation favorites_path = "/Users/{user}/Library/Application Support/com.apple.sharedfilelist/com.apple.LSSharedFileList.FavoriteServers.sfl2" # add these servers if they don't exist already # use a tuple: ("<name>", "<path>") to set a name for the favorite. # otherwise just use a string and the path will be used as the name add_servers = (("My Name", "smb://server.example.com/share"), "vnc://server.example.com") # remove these servers if they exist. Use a wildcard (*) at the end to remove all shares # does not support ("<name>", "<path>") syntax remove_servers = ("smb://old.example.com/*", "vnc://old.example.com") def get_users(): "Get users with a home directory in /Users" # get users from dscl dscl_users = subprocess.check_output(["/usr/bin/dscl", ".", "-list", "/Users"]).splitlines() # get home directories homedir_users = os.listdir("/Users") # return users that are in both lists users = set(dscl_users).intersection(set(homedir_users)) return [u.strip() for u in users if u.strip() != ""] def set_favorites(user, add_servers, remove_servers): "Set the Server Favorites for the given user" # read existing favorites file data = Foundation.NSKeyedUnarchiver.unarchiveObjectWithFile_(favorites_path.format(user=user)) # reformat add_servers to [(name, path), ...] new_add_servers = [] for s in add_servers: if len(s) == 2: new_add_servers.append(s) else: new_add_servers.append((s, s)) add_servers = new_add_servers existing_servers = [] # read existing items safely if data is not None: data_items = data.get("items", []) # read existing servers for item in data_items: name = item["Name"] url, _, _ = Foundation.NSURL.initByResolvingBookmarkData_options_relativeToURL_bookmarkDataIsStale_error_(Foundation.NSURL.alloc(), item["Bookmark"], Foundation.NSURLBookmarkResolutionWithoutUI, None, None, None) existing_servers.append((name, url)) # get unique ordered list of all servers all_servers = [] # add existing_servers to list, updating name if necessary for s in existing_servers: try: idx = [a[1] for a in add_servers].index(s[1]) all_servers.append((add_servers[idx][0], s[1])) except ValueError: all_servers.append(s) # add add_servers if not present already for s in add_servers: if s[1] not in [e[1] for e in existing_servers]: all_servers.append(s) # remove old servers: exact match # matches "smb://old.domain" exactly all_servers = [s for s in all_servers if s[1] not in remove_servers] # remove old servers: shares # matches "smb://old.domain/*" all_servers = [s for s in all_servers if len( [True for r in remove_servers if r.endswith("*") and str(s[1]).startswith(r[:-1])] ) < 1] # generate necessary structures items = [] for name, path in all_servers: item = {} item["Name"] = name url = Foundation.NSURL.URLWithString_(str(path)) bookmark, _ = url.bookmarkDataWithOptions_includingResourceValuesForKeys_relativeToURL_error_(0, None, None, None) item["Bookmark"] = bookmark # generate a new UUID for each server item["uuid"] = str(uuid.uuid1()).upper() item["visibility"] = 0 item["CustomItemProperties"] = Foundation.NSDictionary.new() items.append(Foundation.NSDictionary.dictionaryWithDictionary_(item)) data = Foundation.NSDictionary.dictionaryWithDictionary_({ "items": Foundation.NSArray.arrayWithArray_(items), "properties": Foundation.NSDictionary.dictionaryWithDictionary_({"com.apple.LSSharedFileList.ForceTemplateIcons": False}) }) # write sfl2 file Foundation.NSKeyedArchiver.archiveRootObject_toFile_(data, favorites_path.format(user=user)) # loop through users and set favorites if __name__ == "__main__": # if running as root, run for all users. Otherwise run for current user user = getpass.getuser() if user == "root": users = get_users() else: users = [user] for user in users: try: set_favorites(user, add_servers, remove_servers) # fix owner if ran as root if user == "root": os.system(("chown {user} " + favorites_path).format(user=user)) print("Server Favorites set for " + user) except Exception as e: # if there's an error, log it an continue on print("Failed setting Server Favorites for {0}: {1}".format(user, str(e))) # kill sharedfilelistd process to reload file. Finder should be closed when this happens os.system("killall sharedfilelistd")
We're receiving following errors;
Script result: Traceback (most recent call last): File "/Library/Application Support/JAMF/tmp/Favourite servers MERGE", line 14, in <module> import Foundation ImportError: No module named Foundation
Does anyone have an idea on how to fix it? Or an alternative way to merge & override favourite servers in the Finder?
Big thanks in advance,
Sander.
AJPinto
  • April 5, 2023
MacOS retired python 2.7 early last year, I would start by updating this script to python 3 and adjusting your shebang accordingly.
  • April 6, 2023
The file com.apple.LSSharedFileList.FavoriteServers.sfl2 is protected by TCC so the script will not work.
Unless I am mistaken there is no way to modify this file without disabling SIP.
