Dock settings
  • April 11, 2023
  • 14 views
Hello right now I have the dock set via config profile. The users are able to add items just two things are unremovable. I want to switch to dock utility instead of config profile. The question is can I run a script to backup what their current dock is, remove the config profile and the apply this backed up dock?
1 reply
  • April 11, 2023
dockutil has a list feature, just use --list to get a tab separated list for the current user, or add options for other or all users. Check the usage details on GitHub or run 'docktutil -h'
# list current users dock, returns tab separated list % dockutil --list /* example output Launchpad file:///System/Applications/Launchpad.app/ persistentApps /Users/thisuser/Library/Preferences/com.apple.dock.plist com.apple.launchpad.launcher Google Chrome file:///Applications/Google%20Chrome.app/ persistentApps /Users/thisuser/Library/Preferences/com.apple.dock.plist com.google.Chrome ... Downloads file:///Users/thisuser/Downloads/ persistentOthers /Users/thisuser/Library/Preferences/com.apple.dock.plist */ # list specific users dock % dockutil --list /Users/thatuser # redirect to file for use when rebuilding dockutil --list /Users/thatuser > /tmp/thatuser.dock.txt
