du -sh /directory/path
when excuted from jamf would spit back the size of each folder
du -sh /Users/
Would give you
a decent estimate at least for the home directories; which is where the vast majority of user data would be
The du -sh command will work to get back a size of their entire home directory, or specific directories within it, but keep in mind it's going to be a slow task in some cases. Du is no speed demon, because it literally calculates the size of every single file and then adds it all up into one result. For those users who may have many GBs of files saved in their home directory, expect it to take a while to finish.
For this reason I would recommend using a policy with a script to do the calculation and then maybe save it into a file that can be picked up in an Extension Attribute or in some other fashion. Don't make an EA doing du on people's home folders or it will drastically increase the recon times for every device.
Inventory Record > General > Local User Accounts > Scroll to the right and look at "Size". That should give you a decent idea of how much data is being used for the user profile. Beyond that I probably would not use JAMF to attempt to identify disk usage. Any Commands that could gather this information will take a significant amount of time to process, and tie up all management while they are running.
Thanks! Where the heck is "Inventory Record"?
When you search for a Mac or a Device and click the device name, that is its inventory record.
Thanks! Any idea of how I could get a report that shows the sizes of all the local user accounts in my environment?
JAMF only lets you run reports against the entire disk usage, not just a single user.
A note for posterity - you may need to enable this, at least it was not on by default in my jamfcloud environment. To do so, go to Settings > Computer Management > Inventory Collection > tick Include home directory sizes.
Beware - enabling this will add time to inventory, esp. if you've got folks with many gigs of small files like developers pulling down an entire large software repo. :-p
