GarageBand Essential Sounds Install from Self Service
  • April 25, 2023
  • 16 replies
  • 394 views
Hello,
I am trying to update our method of deploying out the essential sounds for GarageBand through Self Service. In the past, I had leveraged the Carl Ashley AppleLoops script (it worked great!). After Apple removed Python from the base installation of macOS, I had been limping along with installing Python on the devices that were needing the sounds. This has posed other complexities.
Currently, I am testing out installing all of the sound packages needed for the Essential Sounds from a cached copy of those packages on the laptop. This has not produced the desired results yet. The user is still prompted to install the sounds when launching GarageBand. All of the sounds that should be available from the Essential Sounds are present in GarageBand. The loops have also been reindexed in hopes that would resolve the issue.
I would appreciate any help that anyone has to offer.
mickgrant
  • April 26, 2023
Im also trying to deal with this at the moment
  • April 26, 2023
Reach out to your Apple SE.  Something was mentioned in a recent Apple session I attended - not sure of the "agreements" for sharing...
  • September 7, 2023
Hi, Curious if you ever found a way to address this?
  • February 20, 2024
I am just now facing this as well. Was really hoping for a solution that wasn't "download and package all of the essential files."
  • February 20, 2024
I totally understand that!  We gave up, because it was only a limited number of computers that we needed it on, and I sent a tech to each machine to just log in and start them.  Thankfully, they are per machine and not per user if you are in a multi-account environment.
  • February 20, 2024
I am almost there. We only have one class that has specifically requested to use GarageBand, so that's only 20 computers... but I fear as soon as one class starts using it, others will follow, and that could expand to as many as 100 more computers. Oye!
  • February 24, 2024
I have followed several different methods that I have found online to resolve this issue. The solutions that Apple has provided me also have not solved the issue for me. Our environment is too large to have our techs enter in admin passwords for each user who would like to use Garageband. At this point Garageband is mostly unused in our environment due to the installation issues.
If I do find a solution that works for us, I will certainly share it out with everyone.
MCerano
  • July 16, 2024
Hello,
Just wondering if you have been able to find a working solution to this. While our environment isn't too large ~30 machines, I'd like to see if there was a good way to fully automate this process with little involvement from admins.
  • July 17, 2024
Hello,
I have not re-visited it from my previous post.  Certainly curious if others have made any progress though!
  • July 17, 2024
We received a command line tool from our Apple Support team that allowed us to write scripts to download the sound libraries. I am not at liberty to share the command line tool directly, but if you have a contact at Apple, they may be able to help you out.
The tool is simply called "Loops."
Did anyone find a proper solution for this?
  • May 5, 2025
I did not.  I just had a tech go complete the task 1 time on each computer due to a limited number of computers that they were requesting it on.
MCerano
  • May 5, 2025
I was able to obtain the Apple "Loops" software through our Apple rep but I wasn't able to get it to work. The instructions were rather complex and the audio production instructor didn't need to have all of the instrument plug ins after all. I may revisit this in the future if necessary.
  • May 5, 2025
Since you were able to get the loops.sh script, here is the script that I wrote to run the loops script from a policy. Note that we packaged the loops script and deploy it as part of the policy before the below script runs.
FWIW: Parameter 4 in your policy should have the exact command line instructions you wish to add to the loops command. Parameter 5 is either "y or n" depending on whether you want to remove the loops script after the install is complete.
#!/bin/bash ################################################################################################################################### # # Install Sound Libraries # Written by KClose - Created 2025/02/21 # # Calls the Apple loops.sh script from /usr/local/bin/Loops.sh # The "loops" script must have been deployed before running the script. Be sure to include it in a policy. # ################################################################################################################################### ### VARIABLES ### # Retrieve Command Line Arguments if [ "$4" != "" ]; then cliArguments="$4" else cliArguments="" fi # Retrieve cleanup command if [[ $5 == [Yy] ]]; then echo "Loops.sh will be deleted when the script completes. It will need to be reinstalled for future command calls." cleanup="true" else echo "Loops.sh will not be deleted and will be available for future command calls." fi echo "Script command to be run is: /usr/local/bin/Loops.sh $cliArguments" ### MAIN SCRIPT ### # Check for Loops.sh if [ -f '/usr/local/bin/Loops.sh' ]; then echo "Loops.sh script found. Installing sound libraries." else echo "Loops.sh has not been installed. Be sure to include the pkg installer in the policy." exit 2 fi # Call script (with optional arguments) and watch for errors. if /usr/local/bin/Loops.sh $cliArguments; then echo "Loops script run successfully." else echo "Loops script failed." exit 1 fi # Cleanup Loops.sh if [ "$cleanup" == "true" ]; then echo "Cleaning up: removing Loops.sh." rm -rf /usr/local/bin/Loops.sh fi exit 0
I also am in a similar situation, I have to deploy Garageband to several hundreds of macs during deployment. I have the “Loops.sh” script, but I am not able to get it to work. There seems to be an error in the code copied in /private/var/tmp/Loops/Foundation.
Has anybody else had the same problem and maybe found a solution?
  • February 2, 2026
For logic, i was able to do this with two scripts. However i am also having a hard time with this on garageband. I cant figure out where its storing the stupid files….under application support/garageband , under audio/loops/garageband , somewhere else??. I tried installing a few manually, but i cant figure out where they go. So i cant verify if the scripts are putting them in. All i know is that users are still prompted for admin and there are little arrows next to them still, even after packaging the DMG files and installing them….
can take a look at this and see if it helps you or you can figure out the missing piece i am obviously not able to get.. it worked great with logic a year or two ago, same method… not sure why garage band is giving me issues today with it. Seems like it installs from jamf perspective, but i dont know how to verify the install at the file level. I am not the best at OSX, so not surprising. I can never find anything as the mac always goes out of the way to hide things from me!!!
