Since I have not found or heard anything, I have attempted to create this myself. Here is my multi pronged approach, this is not a perfect method however it does work and does a pretty good job. All done without generating embedded credentials to make this process work. I have tried to cover as much as I can.
If there are other Ideas or improvements please share!
When the status is set to Not running or Access_Disabled the device will be added to the following:
Smart Group
Jamf Trusted Access Disabled
Status for EA’s
EA Name | Status Message |
Jamf Trust - Access | Running Not Running |
Jamf Protect - Smart Groups | Access_Disabled |
Jamf Protect custom analytic with smart group
Jamf Protect agent will notify and update smart group when the application has been disabled or closed
( $event.type == 2 AND $event.process.name == "JamfPrivateAccess" )
Jamf EA
Purpose is to detect if the Jamf Trust Access process is running when the device checks in.
EA Name: Jamf Trust - Access
Script:
ProcessName=JamfPrivateAccess
number=$(ps aux | grep -v grep | grep -ci $ProcessName)
if f "$number" = "1" ]
then
result="Running"
elif f "$number" = "0" ]
then
result="Not Running"
Jamf Helper script
Computer Management script named Jamf Access Disabled
This is the script that notifies the end user and will allow the user to enable Jamf Trust Access and if for some reason the workflow is not installed it will not show the enable button unless the workflow is installed.
## Get the logged in username
currUser=$(/usr/bin/stat -f%Su /dev/console)
# Jamf Helper Script for Jamf Protect (Low-Level Threat)
jamfHelper="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper"
#Title for Pop Up
msgtitle="Digital IT Group"
#Header for Pop Up
heading="Jamf Private Access"
#Description for Pop Up
description1="Looks Like Jamf Access has stopped running!
If this is something you have initiated you can disregard this message.
Otherwise if this becomes persistent, Please report to IT."
description2="Looks Like Jamf Access has stopped running!
If this is something you have initiated you can disregard this message,
Otherwise Click Enable to reactivate your connection!
Please report to IT if you suspect anything wrong or if this becomes persistent."
#Button Text
button1="Ok"
#Button Text
button2="Enable"
#Path for Icon Displayed
icon="/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/ToolBarInfo.icns"
if f ! -d /Users/$currUser/Library/Services/access.workflow ]; then
userChoice=$("$jamfHelper" -windowType utility -title "$msgtitle" -heading "$heading" -description "$description1" -button1 "$button1" -icon "$icon")
userChoice=$("$jamfHelper" -windowType utility -title "$msgtitle" -heading "$heading" -description "$description2" -button1 "$button1" -button2 "$button2" -icon "$icon")
if f "$userChoice" == "2" ]]; then
/usr/bin/automator /Users/$currUser/Library/Services/access.workflow
#Remove Jamf Protect Extension Attribute
rm /Library/Application\\ Support/JamfProtect/groups/*
#Update Jamf Inventroy
jamf recon
Created Jamf Pro "PKG" signed build that installs the workflow, with post install script borrowed from @mm2270
This community article
## Check for a 'Services' folder in the user's home directory. Create one if necessary
if f ! -d /Users/$currUser/Library/Services ]; then
echo "Creating Services directory for $currUser"
mkdir /Users/$currUser/Library/Services
sudo chown -R $currUser /Users/$currUser/Library/Services
## Check to see if the workflow file was installed in /tmp
## and copy it to the current user's home Library folder
if f -d /private/tmp/access.workflow ]; then
sudo cp -R /private/tmp/access.workflow /Users/$currUser/Library/Services/
echo "Copied the workflow to $currUser's Services folder"
sudo chown -R $currUser /Users/$currUser/Library/Services/access.workflow
echo "Set permissions on the workflow to $currUser as owner"
sudo chmod -R go-rwx /Users/$currUser/Library/Services/access.workflow
echo "Set access on the workflow for $currUser"
## Exit the rest of the installation if the workflow wasn't there to copy
echo "The Service workflow was not found. Exiting installation..."
/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -title "Installation failed" -description "We seem to have run into a problem getting the service installed for you. Try running the Self Service installation again. If you continue to see this error, contact support so we can help correct this for you." -icon "/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/AlertCautionIcon.icns" -button1 "OK" -defaultButton 1
exit 1
## Now we check to make sure everything is in place
if f -e /Users/$currUser/Library/Services/access.workflow ]; then
echo "The Service was installed"
serviceFile="Yes"
sleep 2
killall Finder
## Final clean up stage
rm -R /private/tmp/access*
Apple Automation workflow
Record a simple workflow to record your action to click the menu item to enable the feature. Note this will also disable access since it only clicks the menu item shown if the user has already enabled before the process kicks off
Application accessibility enablement payload
Since we are activating this workflow within terminal, terminal only needs access to activate this automation and I used PPPC Utility to allow accessibility permissions and then upload.
Identifier: com.apple.Terminal
Identifier Type: Bundle ID
Code Requirement : identifier "com.apple.Terminal" and anchor apple
Accessibility : Allow
Tools Used
Composer
PPPC Utility
Jamf Admin
KeyChain Access
Text editor
@tleadley is this still working for you? I only ask because I tested this hoping it would work for us, JAMF Trust (Private Access), still does not automatically connect on login, restart or sometimes just disconnects.
I have implemented the Terminal PPPC for Accessibility: Allow yet when I run the workflow in JAMF Pro via the script above I get
The action “Watch Me Do” encountered an error: “This application must be allowed to control this computer using accessibility features, using the Security & Privacy preferences located in System Preferences, before using 'Watch Me Do"
The script works fine locally and runs with/without admin access and the workflow runs fine when I run
as well.
as well.
I have had to update this in recent times since initially creating this I have removed the apple automation, it is too unreliable.
I have created a script so it loads at login and I do this on enrollment, it creates the autolaunch and only once per computer
#!/bin/zsh
## Current User
CURRENT_USER=$(ls -l /dev/console | awk '{print $3}')
CURRENT_USER_UID=$(id -u $CURRENT_USER)
launchctl asuser $CURRENT_USER_UID osascript -e 'tell application "System Events" to make login item at end with properties {name: "Jamf Trust",path:"/Applications/Jamf Trust.app", hidden:false}'
Jamf Support suggests, running this line in a policy that runs once a week
open -a "Jamf Trust" "com.jamf.trust://?action=open"
#!/bin/zsh
## Current User
I also got this command from support
open -a "Jamf Trust" "com.jamf.trust://?action=enable_vpn"
I was able to use your script but replaced the entire workflow with this command. Its a deep link that automatically opens and reconnects to the VPN, but does require the intiial registration. For me and my team the registration is not the hurdle, the hurdle is keeping them connected to the VPN always.
