Bit of an annoying problem and was curious if anyone had an elegant method to crack it. Admin wants multiple sites to open by default when Safari is launched. It's easy enough to make a default homepage. I have a custom JSON schema in a config profile for that. I was wondering if anyone knew how to direct Safari to open a 2nd tab as well? I can't figure it out.
Page 1 / 1
not tested. but safari will allow you to save a group of sites in one bookmark.. I guess if you opened that bookmark...
That was my idea as well but I don't think I can push out bookmarks via schema. I know people have had issues with Apple not allowing plist files to change system defaults.
