Smart group based on multiple configuration profile identifiers?
  • May 8, 2023
  • 5 replies
  • 47 views
I wanted to create a smart group that contains computers that have two different configuration profiles installed. That is, both of them, not one or the other.
I created a smart group with the criteria:
configuration profile identifier is XYZ
-and-
configuration profile identifier is ABC
No results. I know for a fact that with have 100+ computers with both installed, mine included. Tried both identifies separately and found all correct matches. But as soon as I add more than one to the criteria, it does not work. Is this expected or am I doing something wrong?
Thanks
sdagley
  • May 9, 2023
@elazer Have you tried Profile Name as your criteria, instead Profile Identifier?
  • May 9, 2023
Name works as intended. Might go ahead and use it, but names can change. Identities would feel more secure.
sdagley
  • May 9, 2023
@elazer At least you have a workaround. I'd suggest you open a support case with Jamf to investigate why you can't use profile identifiers in the same manner.
  • May 11, 2023
@sdagley Contacted Jamf, they suggested trying closed parenthesis around the criteria. That works as well. As in (Profile identifer X) -and- (Profile identifier Y). They would however create a PI since it seems to be a bug.
sdagley
  • May 11, 2023
@elazer Thanks for the followup, very useful to know there is a workaround.
