Packaging VirtualBox and VM
  • June 7, 2011
  • 23 views
Has anyone had any luck packaging VirtualBox and a virtual machine to go along with it? I've reviewed the white paper on VMware and will use it as a guide to get started but was wondering if anyone else had done this with success.
Thanks,
Tom
Tom Anderson
Apple Network Engineer - Institutional Computing
Shenandoah University
1460 University Drive
Winchester, VA 22601
  • June 7, 2011
I did it once following that guide and making allowances for
Parallels. We decided not to go with it over Boot Camp just because of
AD configuration issues etc. Easy enough though to get it working.
*shrug*
Ryan M. Manly
Glenbrook High Schools
  • June 8, 2011
Does anyone deploy VMWare fusion following this whitepaper?
I was under the impression that each copy had its own serial number - that there was no enterprise licensing model so burning a license key into the image wouldn't work. Am I mistaken?
  • April 16, 2013
I am looking to deploy virtual box as a policy. Is there an updated white paper, or post on this?
