iOS Notifications - Show Preview Never
  • June 7, 2023
  • 0 replies
  • 32 views
Can't seem to find an answer to this so I suspect that there isn't (a satisfactory) one...
Security and Privacy best practice says to disable iOS notification previews, especially when a device is locked. This is what I want to set using Jamf Pro.
I know I can set Notification preferences per app, but the setting in the screenshot is global and can be set on the device, but is there a way to configure this device-wide setting with Jamf Pro?
There is a specific Jamf article on this, from the UK NCSC (National Cyber Security Centre), which refers to this specifically, but does not reveal how to achieve this exactly.
https://www.jamf.com/blog/updated-device-security-guidance-from-the-uks-national-cyber-security-centre/
This is the relevant paragraph:
 Hopefully I'm just missing something 🙏
