How to get 802.1X Wifi keychain and User account(AD bound mobile account) password in sync
  • June 9, 2023
  • 13 views
I have 802.1X Wifi profiles with trusted Cert setup.
It works very well until user changes user account password.
Is there a way to change both mobile account and the Wifi login keychain password simultaneously so that users do not need to enter the new password to re-authenticate Wifi?
Please advise.
Hello,
1 reply
  • June 9, 2023
Thank you for your prompt answer. However, I am not too familar with scripts.
Could you please provide me an example if possible?
I believe I can provide it from Self Service that will run those scripts that you mentioned?
