Configuration Profile for Single App Mode freezes
  • June 12, 2023
  • 45 views
I'm trying to set up a configuration profile to put some iPads into Single App Mode. Every time I go to Options > Single App Mode, it freezes.  Even when nothing else has been configured in the profile, it will freeze as soon as I go to the Single App Mode setting.
I've tried multiple browsers but it happens no matter what.
Any suggestions?
Best answer by jtrant
Use iMazing Profile Editor, sign and upload the profile for distribution. Failing that, a private browser window might help. If it does, you need to clear your browser cache.
  • June 13, 2023
  • June 13, 2023
Sorry, I should have prefaced that I use Jamf Pro via the web on a Windows machine. I tried clearing the browser cache and that did not seem to do anything.  However, accessing it through a private browser seemed to let me configure it. Thank you.
